900 & + Modifications This section is specifically for questions and advice pertaining to mods of the older models, 900 and up.
NEED HELP!! keep blowing ignition fuses
Old 06-28-2010, 02:12 AM
asiddle's Avatar
Default NEED HELP!! keep blowing ignition fuses
I NEED HELP!! I got a 93 900RR.just the other day i was riding and out of nowhere it just dies,come to find out i blew an ignition fuse.then i also realized that i blew a right front blinker and my left low beam on my headlights could this all be connected to blowing the ignition fuse?and if so where do i start and what do i check?any help will be gr8ly appreciated have already spent too many hours on this problem.right now i have a 15 amp fuse in place of the 10 and it runs but i know that its just a matter of time b4 it gets worse if i dont find it.PLEASE HELP!!!!
Old 09-19-2010, 05:49 PM
thedudeman's Avatar
You've got a short somewhere.
You'd benefit greatly by picking up some type of service manual. There are links floating around this forum somewhere where you can download them for free, if you want to go that route.
Find out what circuits connect to that fuse, and find out what's shorting out. Maybe there's a switch on the circuit that's failing. The ignition switch comes to mind.
Old 09-21-2010, 03:20 PM
scrape-it's Avatar
My 94 did that when my fuel pump shorted out, i took it out and am running a gravity feed with no problems. It may not be the problem with yours but next time it blows a fuse disconnect the fuel pump plug under the seat, stick a new fuse in it, and try starting it up. if it fires up without the pump plugged in then its shorted between the pump and plug and if it doesnt, then idk what it could be
hmm
05-08-2012 07:57 AM
ZBike
03-24-2012 04:38 PM
Cobretticuz
07-30-2011 02:16 AM
bluefire7321
02-19-2007 12:30 PM
soapdish
10-14-2006 12:33 AM
Quick Reply: NEED HELP!! keep blowing ignition fuses
