Clutch Doesn't Disengage
Old Oct 8, 2025 | 04:20 PM
SpazmaticAA's Avatar
Originally Posted by hamlin6
You shouldn't be able to move that arm with your thumb like that. Check the manual to ensure everything is installed correctly. There should be a spring for each of the bolts you installed. Do you have those?
I have everything installed. 4 clutch springs, thrust washer at the back of the clutch pack, and the washers behind the lock nut on the shaft. The only variance I can think of is using 6x30 bolts instead of 6x28, but even then it's 2mm difference, and I added a washer to the back of each bolt, so it should effectively be 28mm in length.
My dad thinks it's the pushrod in the clutch cover that's bad. Again I have no idea how many times the other idiots before me screwed up a fairly simple clutch job, or abused the hell out of it in other ways.
Old Oct 8, 2025 | 05:01 PM
Your dad may be right. When dealing with stuff like this, it's best to assume that nothing is correct and go from there. Go through the entire basket piece by piece, bouncing it against what the manual states.
Old Mar 9, 2026 | 05:56 PM
So a few months later and I took the clutch out again and even took out the drum to see if there was anything missing or improperly aligned. Nothing out of place, and the clutch still doesn't disengage. Play also looks about the same in the clutch arm. Gonna get a piece of stainless steel and make a new pin and see how that goes.
Old Jun 3, 2026 | 04:13 PM
Currently have the clutch out for like the 3rd or 4th time now. Nothing is missing, and even making a new clutch push rod hasn't solved the issue. Right now we're trying to see if we can even get the dang thing to disengage outside the bike. Currently it seems like there is no play at all in the clutch. (As in we can manipulate the clutch to get seperation even without the spings in the basket.) Is there a post or video explaining how this particular clutch is supposed to operate? I'm completely at a loss for what I should be looking at right now.
Old Jun 5, 2026 | 11:02 AM
Try taking a pair of plates out.
This should show whether it’s the mechanism jammed or the basket is really over full.
Old Jun 10, 2026 | 04:04 PM
So when I first saw your post I was going to call you an idiot, but I thought it through and realized you might be right about removing the plates. Just came back from taking the plates out, and my clutch works like it supposed to!
I also measured the thickness of the old and new plain plates, and the new one was about .040" thicker than the old one I measured. So my next question is whether I can run the bike with 7 plain and 8 friction plates instead of the normal 8 and 9?
Old Jun 11, 2026 | 02:14 AM
Does it slip under full power?
If not then go for it.
Mark9
Sep 19, 2022 01:58 AM
RyanEricW
Sep 8, 2010 11:34 AM
dougcrx
Mar 30, 2008 01:52 AM
JonBrown
Oct 15, 2007 06:25 PM
TBone
Aug 8, 2007 06:50 PM
