TRG Coating TRG Coating is a small shop specializing in custom powder coating, batch powder coating, thermal barrier coating, and much much more. Our areas of work include automotive, motorcycle, ATV, marine, medical, and even lawn furniture. Basically, if it's metal, we will coat it for you with the proper formulation and the correct process.
Some questions before i order
Old Nov 9, 2006 | 10:37 PM
rancidf4i's Avatar
Default Some questions before i order
First off are you back to the $90 a rim charge?What is return ship charge as well or is it included?
What kind of turn around time do you have once you recieve the rims at your business?
How many coats do you apply to the rim as well because ive been told buy a few places that it usually takes 2?
Do you put a final clear-coat or does it not need it?
The pic that is below that you did what all is on this, cause it is exactly what i'm going to order from you
[IMG]local://upfiles/7059/5A6B51A45E7B4F62B5D657A4DD1B3680.jpg[/IMG]
rancidf4i's Avatar
Default RE: Some questions before i order
oh yeah Thanks!
Old Nov 14, 2006 | 10:30 PM
TRGcoating's Avatar
Sorry for the delay. Price is back to $90 per wheel. Shipping is about $20+ depending on location. As far as turn around it would be about 3-4 days sometimes less. The rim pictured is candy red, no clear coat. This is a 2 stage powder with a silver basecoat and candy red top coat. NO clear is needed as the candy red is essentially a tinted clear coat. You do NOT want to pile on the coats with powder. The thicker it gets the more brittle it gets and the easiar it chips. Where are you located? I can probally do $200 shipped to your door.
jpw
Apr 24, 2020 02:28 PM
nrmskate
Mar 26, 2012 07:23 PM
MajorMods
MajorMods
Mar 20, 2012 08:18 PM
gump
Aug 19, 2010 12:22 AM
corrado007
Nov 26, 2008 09:01 PM
