Stunters Corner For all those stunters out there.. share your knowledge, talk about it. Those that do not like stunting, please stay away. Please read disclaimer!
wiring
Old 08-21-2007, 07:45 AM
JZHALES's Avatar
Default RE: wiring
sorry last time i did something wrong
[IMG]local://upfiles/9839/F86ED4982F1B47459E149867A3C17197.jpg[/IMG]
Old 08-21-2007, 07:46 AM
JZHALES's Avatar
Default RE: wiring
bike is def alot more crunchy than that now and different color that was right before the stuntation took place last september
Old 08-21-2007, 09:52 AM
Northernfirepower's Avatar
Default RE: wiring
I also have an aftermarket headlight pod on mine. I wanted to unplug the entire front harness but needed the signal relays for the turns and so I have all that crap stuffed behind the pod and it is quite tight.
Old 08-21-2007, 11:26 AM
DDCavi's Avatar
Default RE: wiring
On my F3 I stuffed most of the wiring harness into the ram air duct and what I couldnt get in there I stuffed under the tank. I had to scrap the air ducts from the ram air to the airbox cover.
Old 08-21-2007, 05:51 PM
Err's Avatar
Err
Err is offline
Default RE: wiring
ORIGINAL: Vermino
well talking about your bikes, why havent i seen a picture of yours Err or JZhales?
b/c mine is hideous. i don't know why anyone would want to see it, my new paint is baller tho....
Old 08-21-2007, 05:53 PM
JZHALES's Avatar
Default RE: wiring
not everyone rocks 06 1000RRs some of us have crunchy bikes with things missing, taken off, usualy snapped off, or zip tied on. i wouldnt have it any other way
Old 08-25-2007, 10:25 AM
Default RE: wiring
i dont remember what wires i cut and connected, but i bypassed the tip over sensor on the main harness under the seat. so now the only wires i have up front is for the low beam. but i have that tucked and ziptied to the cross bar behing the neck of the frame. you cant see a thing. the only wires you see are from the ignition. if you dont want to trim down your entire harness then run the connectors for your tach and lights through the small space between the radiator (the two brackets on top of the radiator) and neck of your frame. it moves the wires from the side of your frame for a cleaner look.
Old 08-25-2007, 10:29 AM
Default RE: wiring
no wires
and no hands. hahah
bigwill74
03-05-2013 02:56 PM
leonf4i
10-10-2009 07:24 PM
AALBA2
03-31-2008 08:55 AM
93_ka24det
03-25-2007 06:38 AM
mastice
11-26-2005 04:37 AM
Quick Reply: wiring
