Stunters Corner For all those stunters out there.. share your knowledge, talk about it. Those that do not like stunting, please stay away. Please read disclaimer!
wheelie problems
Old Nov 12, 2006 | 07:38 PM
Slow900RR's Avatar
Default wheelie problems
ok guys i have a 98 900rr with a d&d skip and -1 +2. ive been trying to do second gear wheelies but when i reveit up and dump the clutch it just jumps up like a inch for a split second. i think its the clutch but whats you input.the sitting or standing witch is easyer. and how in the hell do you stand i tryed its hard. if anyone has a suggestion on how to make it easyer that would be awsome. thanks guys
jim
Old Nov 12, 2006 | 09:36 PM
JVracer04's Avatar
Default RE: wheelie problems
(in second gear) go about 45,
(step 1) grab the clutch and let off the throttle
(step 2) slam the throttle and pop the clutch (this should be done very fast and simotaniously)
(step 3) hold your hand on the throttle until u feel your heart drop
(step 4) let off the trottle just a hair and start to drag your foot on the rear brake
im still practicing the stand ups, so iono bout that one (stand ups and sit downs have complete different throttle responses)
if your bike honestly only jerks and doesnt come up in the air more then 12" then u may need a new chain
Old Nov 13, 2006 | 12:10 AM
JZHALES's Avatar
tighten your chain homie that helps sometimes
Old Nov 13, 2006 | 04:56 AM
EULOGY's Avatar
if it's the clutch your worrying about... just pop it up in 1st if you can then its not ya clutch.
ps: but ya, your chain or your throttle might need to be re-tightened.
Old Nov 13, 2006 | 09:51 AM
Slow900RR's Avatar
thanks for the in put. i havent tryed second gear wheelies lately. the chain was brand new and tight when i was trying . im replacing the clutch over winter hopefully it will help. thaks guys
Old Nov 14, 2006 | 02:19 AM
DThompson's Avatar
Maybe you are just going to fast to be doing wheelies. Slow up a little bit when you are clutching it. That might do the trick because I noticed with my old f4i that I was just going to fast.
Old Nov 14, 2006 | 03:51 PM
Err's Avatar
Err
dude all you need to do is give it more gas, and shift your weight over that rear wheel. i have the same bike and almost the same gears (-1+5) you'll need a significant amount of throttle to get the front wheel up.
it WILL come up, just keep at it.
Old Nov 15, 2006 | 02:07 PM
gixxereater's Avatar
I had a 99 900RR with -1 and full exhaust and it would come up in 2nd just off the throttle if you had your timing correct. Clutching was not a problem. Practice
Old Nov 29, 2006 | 03:08 AM
JAYS900RR's Avatar
I HAVE A 99, 98 ,97, AND 95 900RR. GO ABOUT 30-35MPH IN SECOND GEAR,
SIT AS FAR BACK AS YOU CAN PULL IN THE CLUTCH HIT THE GAS HARD AND
LET THE CLUTCH GO REMEMBER TO COVER THE REAR BREAK... SEE HOW IT GOES UP..
THEN JUST GET USE TO IT..AND GO FASTER AND FASTER.. AND HIGHER AND HIGHER..
AND MOST OF ALL ENJOY THE RIDE...
Old Dec 8, 2006 | 05:07 AM
EULOGY's Avatar
ORIGINAL: JAYS900RR
don't get the wrong idea but, i'm gonna have to disagree with that; for a beginner you'd want to stay close to the tank and squeeze the tank with your legs. sliding back on the seat makes you less stable and as for the stand-ups... get your sit-downs first.
m21oliver
Oct 1, 2018 10:52 AM
fastandloud
Aug 28, 2010 06:14 PM
dmbnpj
Jul 21, 2008 05:31 AM
cr cbr
Nov 28, 2006 04:36 PM
