How to keep a wheelie up?
RE: How to keep a wheelie up?
Nothing wrong with the bike just the user. Its all about how you slip or pop the clutch. If your getting the bike up and its not going straight to BP then you need to use the gas to get the bike to BP and rear brake to keep it there. Takes some pratice to get there, so just keep tring and sooner or later you will get it.
If your just going up and down you are slipping the clutch and then letting off the gas(close the throttle). You will quickly find out the higher you go the slower you go and the farther you will go. You will know when you hit BP the bike will be floaty and will take not extra throttle to stay up(you will stay at a constant speed)
Thanks for the reply.
Yah, that must be the problem, closing the throttle once it pops up. I guess I am nervous letting it get too high too quick. I feel like I'm going to flip over backwards. I have gotten in the habit of covering the rear brake but I haven't had to use it because it just pops up and then goes right back down. Again, must be because I am releasing the throttle. Shouldit be fairly easy to keep it up in first gear or should I be trying to pop it up in second?
I've seen others pop a wheelie going at least 50mph. Im wondering how do they do that?
Thanks again
Thanks again
Yeah i have a problem keeping it up too. I'm still stock and i can power it up in first or clutch it up but as soon as I get up thier I ease off the clutch and comes right back down. I'm not even letting off the throtle very much either. I can ride wheelies good on dirt bikes and four wheelers though. I don't know what the problem is.
Its definately not the bike I am 225lbs and was killin it on a bone stock 01 f4i .My best advice is PRACTICE,PRACTICE, PRACTICE.....THEN PRACTICE SOME MORE !after that,practice some more .....and so on.remember that most people that have been doin this awhile practiced their *** off and probley tore their bikes all to hell,so if your **** is MINTY,take the plastics off and get a powersstuntworx cage.....it will save you money. oh yeah, GET HEATH INSURANCE!!!!!!!!!!!!!!!!!
Yea, practice is your best friend. I have only been riding for 5 or so months, but I ride everyday and endlessly practice everything I do. I even ride in the rain to practice and to get the feel of the bike on wet roads just in case I'm in a bad spot and need to ride in the rain for a real reason other then I'm stupid and want to.
I learned to start riding a wheelie by simply powering up first and getting used to floaty front end. After a little bit of that, I just used throttle control to keep the front wheel off the ground while still under power(no were near BP). So you come up around 20-30 and go down around 70. That takes maybe a city block when your just using power to keep it up. After I did that for a while, I started to power up to my normal spot and then give it just a tad more gas. Just remember when you think your at BP your more then likely not, your still aways away. If you are in first you have engine braking to help slow you down and bring the front down if your rear brakes skills are not there yet. If you can ride out first all the way to red line, then start trying to clutch em up. Don't pop the clucth just slip it and give the bars a tug or the bike a bounce.
When I bought my 12 bar(just to have it at first didn't really need it) that helped a ton with learning how far back it really is. I put my bike at 12 in my drive way and just sat there with it. You learn a lot sitting like that.
