help on fighter headlight mount
Old Mar 8, 2012 | 10:06 PM
TeamAeD1's Avatar
Default help on fighter headlight mount
so i need help with a headlight mount. ive seen all these uni mounts for harleys and such that wrap the forks. non of which will fit my forks. so pics would help for ideas....
Thanks...
Old Mar 9, 2012 | 07:00 AM
colorado_steve's Avatar
we need more info, what bike, what headlight, what size forks
Old Mar 10, 2012 | 02:54 PM
TeamAeD1's Avatar
f4i with 954rr forks, trip trees. i believe they are 6" to 6 1/4" round with this headlight.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
i have access to alot of machine shop equip as for fab is not a problem but what i came up with is just make a cut out of a bracket out of 60k aluminum and just bend it around the forks and clamp it with a rubber seal in between the aluminum and forks.
Old Mar 10, 2012 | 04:49 PM
Conrice's Avatar
they're 50mm forks. you can make mounts out of aluminum stock. you can bend and wrap it around a 50mm pipe (and that's 2in. straight up) to fab the mount.
Old Mar 10, 2012 | 11:07 PM
TeamAeD1's Avatar
what k should i get the aluminum in. and the measure is 50mm, your right i converted it. thanks a bunch. what k should i use? i used a 60k for my mount for the cluster which turned out amazing but they were done on a break. 60k is really hard to form by hand?? i thought about 40 but would vibration hurt them even though a taper/radial them for it? sorry for the edit.
Old Mar 10, 2012 | 11:20 PM
TeamAeD1's Avatar
oh and conrice i love your build. your doing an awesome job with that single side swing arm. "jealous" thanks for your input as for i like to critique my bike too. surprisingly i bought a shhhhhhhiiiiiiiisssssstttttttyyyyyyyy bike and trying to beauty it. its hard but im almost done before tear down and repaint .
jtellis26
May 1, 2012 02:43 PM
JankCibberf2
Jul 27, 2011 04:35 PM
sward220
Apr 18, 2008 08:43 PM
