loose change
RE: loose change
didn't work on the coke machines i've got in my building where i work at school. It may have to be the same type of machine as the one they used in the video.... the one i tried had a round metal putton you push in for the coin return, instead of the tab you pull down like in the vid.
RE: loose change
hey guys i work at pepsi and fill pop machines..........lol. I am going to try it at work and see if it will work. I don't think it will because there is way more change in the changers then that. They can hold about 34 bucks work of change. We use ton's of different changes and i have seen lots of breaker box knockouts and quarters with string or people shove paper in them. I have seen about everything that can be done to one. A fire extingisher and a sledge hammer make a pretty good set of tools. freeze the lock with the extingisher then smack the lock with the hammer. On the downside it's alot of work for less than 100 bucks, but they get broken into all the time.
