Need help!! I need to remove cat smell
As sad as it sounds, depending on your carpet type (thickness and pad/no padding) if the cat urine soaked through to the padding if you have padding under your carpet, the smell may only be removed if you either let something soak into the pad or remove the carpet and the padding altogether. I had this exact same situation with a cat with the same scenario and we eventually just got rid of the carpet. We did use many products, but the smell just lingered.
If you don't have padding, then pinesol and a scrup brush should do or some specialty carpet cleaner.
Good luck.
Good luck.
Vote for Nature's miracle
You have my vote for Nature's miracle.Quote from manufacturer:"Nature’s Miracle Stain and Odor Remover removes the oldest, most stubborn set-in stains and odors from carpets, floor and other surfaces that other products have failed to remove."I actually just purchase some two days ago from my favorite cat supplies store, purfect cat supply. You can check it out Nature's MiracleElizabeth
LOL you just joined a CBR forum, and THIS is the topic of your first post? Anyhoo. . .
+1000 to Nature's Miracle!!!!!!!!
I deal with stray cats a lot, and this stuff is the ONLY thing I've ever found to work. You have to follow the directions EXACTLY though: throw a couple of towels down on the spot, and put something heavy on top of them for about an hour. I like to use a flat board, and my 40lb tool box. That will squeeze the padding and soak up a lot of the pee. After that, shake up the Nature's Miracle, and put it into some kind of squeeze bottle with a nozzle (I happen to use an old Rain-X anti-fog bottle). Stick the nozzle into the carpet in a couple of areas around the center of the spot, and squeeze it out forcefully. The idea is to do just wahat the pee does - hits the carpet in a very small area, but spreads out into the padding. After that, sprinkle some onto the carpet itself, and scrub it around with a towel. Then do the towel \ toolbox thing again, then air dry. it will effing STINK for the next couple of days, but that means it's working. After that, the smell should slowly diminish until the padding is dry. I throw a fan on it to speed it up, and blow the stink out a patio door or something. Some takes a couple weeks to dry completely, so be aware. Yeah it's a long time and a pain in the ***, but nothing else works this good. If it still smells afterwards, then you either didn't soak it enough, or you didn't dry it enough.
WARNING: do a color fastness check. I had an area rug that this stuff totally bleached, but I've never had a problem on carpeting (check anyway).
Pet Supplies Plus carries it.
antatious
F2 Tech
08-23-2010 05:31 PM
