2023 CB125R - torquing turkey?
Old Mar 17, 2025 | 07:47 AM
DanielBe's Avatar
Default 2023 CB125R - torquing turkey?
Hi, am I in the right place!? Is this the category for modern CBR!!?
2023 cb125r neo sport.
We (son and I) are looking to replace the steering head bearing, as after a low speed drop the steering is notchy. I think we've busted something...
While getting to this and removing the forks we have noticed the damping is different on each fork - so we'll remove and replace the oil in each too.
My questions are about torque specs and fork oil specs.
What are torque specs for:
Front wheel nut
Axle pinch bolt
Axle clamp bolts
Fork bottom yolk
Fork top yolk
Fork damper nut (top of fork that screws on to the damper piston)
Steering head set nuts, if any. Or is it done up so it's tight but not binding?
Handlebar holder/clamp bolts
Brake caliper bolts
Fork oil
What fork oil
What level in mm (measured from where)
Thank you! Can't find this data anywhere, as we can't find a manual for this bike...maybe it's too modern!
Old Mar 17, 2025 | 08:34 AM
Hi there, yep does not look like there are any on line.
Only thing I can suggest is to give your local bike shop a ring and see if they can provide you with the torque figures.
Old Mar 17, 2025 | 08:42 AM
DanielBe's Avatar
Thanks. Do you mean in order to get a general idea of the torque specs - I have other manuals so I have some reference material, or do you mean ask a Honda Dealer as they will have access to their specific shop manuals for our model?
Thanks and apologies if seems obvious!
Old Mar 17, 2025 | 09:08 AM
I would try the local Honda dealer or if from a shop where you bought the bike.
Old Mar 17, 2025 | 09:09 AM
DanielBe's Avatar
Thank you!
hmm
Oct 19, 2013 04:02 PM
DomesDKG
How-To: Mechanical
Jul 1, 2012 08:21 PM
oldZRguy
Apr 22, 2009 09:30 AM
jalate compa
Nov 1, 2008 07:14 PM
SJN
May 27, 2008 12:39 PM
