fork oil
Old Nov 1, 2008 | 07:00 PM
jalate compa's Avatar
Default fork oil
hi to all i just have a question where should i put the fork oil into forks?
do i only have to remove the big nut cap in the handle bar and render the 15 oz
in to??? or wich is the right procedure?
Old Nov 1, 2008 | 07:14 PM
Hurricane rider's Avatar
Default RE: fork oil
you need to remove the wheel, pull the damper bolt, then the fork spring by removing the cap on top of the fork. you measure the fork oil with the tube fully compressed and the spring removed from it. I posted the fork oil measurements somewhere else. just look up fork oil height or level.
FlyWheel
Sep 18, 2012 07:49 PM
driyac
Jul 11, 2010 02:40 AM
civicblade
Apr 23, 2009 08:24 AM
WhiteHawk
Mar 17, 2009 10:17 AM
crx2cbr
Jul 6, 2008 01:56 PM
