any more hints?
Old Nov 1, 2008 | 02:40 PM
el bimbo's Avatar
Default any more hints?
ok took apart the bike today found that the boots from the carbs to the engine were loose i took the carbs off to do what the mech at the dealed told me to to turn the lil srcews at the bottom of carbs all the way in and come back out 2 and a half turns did taht got on the freeway feels like alot more power but still missing at idle go up and down a lil till turns off any hints ? thanks for the help
Old Nov 1, 2008 | 03:09 PM
Sand.Man's Avatar
Default RE: any more hints?
One hint for forum etiquette - instead of creating a new thread every time you need to ask the same question, post in your old thread and it automatically goes to the top of the list with all of the other information you've already typed.
How tight did you thread the mixture screws in? They should not be tightened any more than "Lightly seated" or you will damage the needle end of the screw.
I would take them out and inspect them if you think you tightened them too much, be careful - they have a spring and an o-ring inside that will fall out when you remove the screw.
2 1/2 turns out from lightly seems too far,
1. Try2 1/8 turns.
2. Warm up the engine to operating temperature (stop-go riding for 10 mins)
3. Set the idle speed to about 1200 RPM +/- 100rpm
4. Turn the pilot screwsout 1/2 turn counter-clockwise from the initial setting (2 1/8 turns out)
5. If the engine speed increases by 50rpm or more, turn all pilot screws out by successive 1/2 turn increments until engine speed does not increase
6. Adjust the idle speed back to 1200rpm
7. Turn the No. 3 carburetor pilot screw in (clockwise)until the engine speed drops 50 rpm
8. Then turn the No. 3 carburetor pilot screw counter-clockwise 1/2 turn from the position obtained in step 7.
9. Adjust the idle speed back to 1200rpm
10. Perform steps 7, 8 and 9 for the No. 1, 2 and 4 carburetor pilot screws.
Check to see that your fuel lines are not restricted.
Your float level may be mis-adjusted.
Check your fuel tank breather tube, may be plugged.
Old Nov 1, 2008 | 03:16 PM
el bimbo's Avatar
my bad man pero now i know
those are the ones that are out side on the float bowl right not the ones inside ? are we talking about the same ones
and to your ? i just went in till they stop then came out 2 and a half turns is that right ?
Old Nov 1, 2008 | 03:23 PM
Sand.Man's Avatar
Yes they are the screws accessible from outside of the float bowls, be very careful not to tighten them past the point that they stop turning - be very gentle when screwing them in.
Instead of 2 1/2 turns try starting with 2 1/8 turns, read my first post again - I updated it with some information to help you set them up properly.
Old Nov 1, 2008 | 03:32 PM
el bimbo's Avatar
thanks man ima try that right now cuz the mech down the street wants to charge me 300 to get it running right and stop missing hope i can do it my self then off to the next thing i have to fix
Old Nov 1, 2008 | 03:47 PM
el bimbo's Avatar
can you do that with out takeing off the carbs ? and if i take the carbs offis there anything i can do to the carbs that will help
Old Nov 1, 2008 | 04:07 PM
Sand.Man's Avatar
It's better to do that with the carbs on the bike, as the motor has to be running to verify your adjustments.
If you take the carbs off, you should check the adjustment on the float levels, and clean the carbs extensively with compressed air and carb cleaner (be sure to remove all rubber components like gaskets and o-rings)
Old Nov 1, 2008 | 05:27 PM
el bimbo's Avatar
well i burned the hell out of my arms but i got it to idle nice and easy at about 1500 rpm never before i got on the freeway opened it up pulled in the cluch while rollin on the road bike turned off turned it on and got on it again got home and idleing bad again also i checked the headers 1 and 2 are alot hotter the 3 and 4 befor ei left it was idleing good and didnt smell like gas no more and on the screws you told me to turn i tryed the best i could it sucks when u dont have all the right tools
Old Nov 1, 2008 | 05:43 PM
el bimbo's Avatar
oh yea hey hershey i cant put my bike at 1200 it will die when its under 1500 and at 1500 -2000 its rough
Old Nov 1, 2008 | 05:59 PM
Sand.Man's Avatar
I think your float levels are off, read this website to learn how to set them.
http://www.factorypro.com/tech_tunin...procedure.html
You must remove your carbs from the bike to set these.
Set your floats to 13.7mm (0.54")
