tips for a touch up
Old Nov 11, 2009 | 02:11 PM
penguin26's Avatar
Default tips for a touch up
ok so the other day my bike tipped and scraped on a brick planter while trying to shimmy between a car and the planter to a garage but anyways i wanna sand and spray paint but i've never done it so i'm looking for any and all advice on what to use and how to do it. here's a pic of the scratches and thank you in advance for your help
p.s.
yes that is a penguin who hoes by Chilly ***** lol..i love penguins hahaha
Old Nov 11, 2009 | 03:29 PM
Kuroshio's Avatar
You're gonna lose Chilly, I'm afraid.
Gotta sand the paint in the damaged areas completely down.
Thin layer of bondo to fill the scratches in.
Sand that down till even with the existing surface.
Wet sand the entire the area with starting with about 320 grit, scaling up to 600 grit.
Primer (wet sand some more)
Paint (guess what? yeap, more wet sanding!)
Clear coat
Your arm tired yet cause it's time for... More wet sanding (fine grit 1500 - 2000 and lightly so not to cut through the clear coat)
Buff and Polish
Old Nov 14, 2009 | 09:07 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Those scratches aren't too bad and after using some matched touchup paint it will look ok.
Yeah, unless you have a show bike, just touch it up & forget about it.
Old Nov 14, 2009 | 09:09 PM
Sprock's Avatar
Time to get Chilly ***** some little penguin pals to talk to
Old Nov 14, 2009 | 09:31 PM
Shadow's Avatar
Colorite have touch up in factory colors..............
Old Nov 15, 2009 | 01:23 AM
penguin26's Avatar
thanks for the tips..i think imma try the touch up first and go from there. hopefully it won't come down to rattle can. any tips on where to get some quality touch up paint? i was thinking auto zone or pep boys...
Old Nov 15, 2009 | 01:46 AM
justasquid's Avatar
AutoZone or Pepboys wont beable to match your paint. Shadow already suggested the best place, and thats Colorrite.. If you get the jar with the small brush, use it very sparingly and put on as light of coats as you can. It builds up fast. You dont want raised areas where your stratches use to be.
oh yeah, and try using some masking tape and run it along the stratches so only the unpainted part is exposed. Its much easier to avoid excess paint.
http://www.colorrite.com/
cbrfxsmithy_6_7
May 24, 2012 04:38 PM
cwmc29
Jul 23, 2008 09:08 PM
Hayden06F4i
Jan 15, 2008 08:25 PM
jsmith2154
Nov 2, 2007 01:13 AM
Repsol_Thom
Jan 26, 2006 03:50 AM
