replacing stock airfilter
Old Apr 9, 2006 | 12:34 PM
fastmofo's Avatar
Default replacing stock airfilter
I own a 2004 cbr 600 RR and still running the original oem air filter @ 11,000 miles. I ride in pretty normal conditions but would like to know when ill need to replace it possibly with a K&N? I tried getting to the airbox and found that it was a pain in the *** to get to. Anyone have any thoughts or a websight that will show you an easy way to do it yourself??
Old Apr 9, 2006 | 03:12 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: replacing stock airfilter
I think the strategy for getting to the air filter on the 600RR is the same as the 1000RR. Just remove the plastic tank shell and then a couple screws in the airbox. You may have to prop up the tank -- I forget. Still, not really difficult to do. When you put the tank shell back on, squirt a little soapy water around the filler cap hole. It'll make getting the seal on a lot easier.
Maintenance schedules usually call for replacement at 12K miles.
radboy58
Jul 27, 2009 04:36 PM
CosmoBob
Jun 6, 2008 12:39 PM
CBRFREEK
May 4, 2006 11:49 AM
