question
Old Mar 29, 2008 | 07:42 PM
118367s's Avatar
Default question
if my altornator is not working would the cover be cold or would it be hot cuz the bike wont stay charged i know this might be the wrong section for this but i dished out almost 2 grand on the bike[:@]
Old Mar 29, 2008 | 10:25 PM
FireStourm's Avatar
Default RE: question
Usally best way to test if your alternator is working either charge your battery fully than ride your bike. If it either dies or runs really low on juice its probably a bad alternator. Now if you plug the battery in and it doesnt take a charge at all the battery probably isnt working. Or get a battery charger with an alternator tester built in. Sorry but best I can think of at the moment just got off 16 hours of work and a little tired.
Alec
Old Mar 29, 2008 | 11:19 PM
socale30's Avatar
throw a multimeter on the battery with the bike off. get a reading.
turn the bike on, check the multimeter. you SHOULD see a change in the reading (voltage should go up).
if it remains the same, or goes down...you know you're stator is donezo.
also, check all the wires going to the R/R. if a wire is broken/loose, it could cause the battery to not get a full charge (happend to a friend)
Old Mar 29, 2008 | 11:23 PM
bwayers's Avatar
on cars all i do is with it running i disconnect the negative battery terminal - if it continues to run your alternator is ok
if it dies, time for a new one
never done that to a bike but i assume it'd be the same way
Old Mar 30, 2008 | 01:01 AM
socale30's Avatar
dude. NEVER disconnect the battery while the car is on. you can fry your ECU. The battery serves 2 main purposes. 1. holds a charge to start the car. 2. acts as a filter or buffer for the current coming off the alt. The charge from the alternator WILL spike every once in a while, and the battery absorbs the spikes so it doesnt damage any critical electronics (like teh ecu). thats why most manuals state in bold print to never remove the battery while the vehcile is running...
Old Mar 30, 2008 | 01:04 AM
HAVOC's Avatar
here is how to diagnose your charging system https://cbrforum.com/m_405789/tm.htm
Old Mar 30, 2008 | 01:17 AM
Redd's Avatar
Buy a multimeter at radio shack...15 bucks.
Old Mar 30, 2008 | 09:58 AM
FireStourm's Avatar
Nice write up thanks for the link Havoc its been book marked.
odano1988
Sep 15, 2015 07:26 AM
bammerman
Jun 12, 2010 12:32 PM
600f4iHUNTERDON-NJ
Oct 8, 2009 10:30 AM
sempul
Sep 11, 2009 09:38 PM
viva_brasil
Jun 9, 2008 04:38 AM
