probably a stupid questin...
Old Sep 30, 2006 | 12:52 AM
JZHALES's Avatar
Default probably a stupid questin...
Rake, and Trail? what does that mean?
Old Sep 30, 2006 | 02:02 AM
Shocktroop's Avatar
Default RE: probably a stupid questin...
Rake is how far out the forks are from the body of the bike, as in a degree of angle..."Man, those forks are raked, or it's raked.." No idea about trail but I'd think it has to do with the swing arm or rear tire...or, I could be as clueless as you....
Old Sep 30, 2006 | 02:27 AM
holycrapitshassell's Avatar
trail is the difference between your steering axis @ ground level and bottom dead center of your front wheel
i'll draw a picture, lol
*edit*
nah, nvm, thats too hard, lol
Old Sep 30, 2006 | 02:20 PM
doncollins's Avatar
Retired Administrator
I'm not sure if I can explain trail any better than what's already here. Trail .. too much is bad. That's all you really need to know here. You should have to worry about it unless you're planning on make a chopper out of your CBR. Too much trail at high speeds and you bike wants to stay straight and at low speeds the front will try to flop to one side and be unstable.
Old Oct 1, 2006 | 11:12 AM
scouperacer1994's Avatar
From what i gather trail is most comparable to caster if it where a car.
Old Oct 1, 2006 | 08:14 PM
mlcjr's Avatar
Rake is the angle between the headset tube and a vertical line. Increasing the rake will move the front tire farther from the bike. Rake is measured in degrees, and is a frame specification. To visualize trail, draw an imaginary line along the path of the headset tube to the ground. Measure from this point to the center of the tire patch. This is trail, and is measured in inches.
The amount of rake is significant in determining a motorcycle's handling characteristics. In general, more rake provides greater straight line stability, less rake makes the bike more responsive. Larger values of trail also create more straight line stability. This is why the forks on a sportbike are more vertical than those of a cruiser.
from www.totalmotorcycle.com/
And my mom told me that there are no stupid questions and no one messes with mom....
Old Oct 1, 2006 | 10:00 PM
snowboarding82's Avatar
What is trail braking then? I thought it was just using the rear to brake like you would on a trail bike.
Mike
Old Oct 1, 2006 | 11:12 PM
mlcjr's Avatar
ORIGINAL: snowboarding82
Mike
You're right, trail braking is using your rear brake. Trail is something else, here is a good article on trail braking.
http://www.sportrider.com/ride/RSS/1...trail_braking/
also mike
jveach
Jun 12, 2011 12:45 PM
MartiniRossy
Jun 11, 2009 02:42 PM
onewheelneil
Oct 12, 2007 05:05 PM
onewheelneil
May 9, 2007 07:49 PM
bowtiepwr
Aug 18, 2005 05:24 PM
