Plug a tire?
Old Feb 8, 2008 | 02:22 PM
Lrn2Go's Avatar
Default RE: Plug a tire?
ORIGINAL: some guy #2
I couldn't find any shop that would patch a motorcycle tire.
Probably not a good sign...
Old Feb 8, 2008 | 02:24 PM
jutsin's Avatar
don't use a plug they're garbage, use a combination patch-plug, it is a patch with a rubber plug attached that you pull through from the inside. If done properly it will outlast the tire.... if the puncture is not straight up and down and in at an angle, or if it is not dead center on the tread, i wouldn't do it on a motorcycle- they have such a rounded profile that the patch area wont sit flat against the inside of the tire
Old Feb 8, 2008 | 06:40 PM
VP's Avatar
VP
I road a patched tire to 170 mph and put got over 6k miles on it... managed to pick up another nail before it finally went
Old Feb 8, 2008 | 07:07 PM
NY Erion929's Avatar
IF you do it(I wouldn't) make sure you use an Internal plug... It gets put on from the inside
Old Feb 8, 2008 | 07:11 PM
RCR's Avatar
RCR
Plug it. Just don't burn off,could possibly pull it out.
Plugs aren't that bad or dangerous if there in the tread not the side wall.
Old Feb 8, 2008 | 07:15 PM
crazyhorse95gt's Avatar
ORIGINAL: NY Erion929
^This is the only way to go^ Do it from the inside. I've used the plugs and never had a problem.
Old Feb 8, 2008 | 07:55 PM
letsride's Avatar
I have used a plug patch and ad no problems.I used to manage a auto shop and I would always plug patch motorcycle tires for free when they came to me.And yes good luk finding someone to fix it for you.Most places won't take the chance of getting sued for it.Don't use a plug because it can work its way out and it also destroys the steel belts when being installed.
Old Feb 8, 2008 | 08:07 PM
rangerscott's Avatar
Wouldnt a patch be better than a plug?
Old Feb 8, 2008 | 08:09 PM
letsride's Avatar
On a car yes,but not on a bike.
Old Feb 8, 2008 | 08:13 PM
OKIEZAC's Avatar
my life is worth more than a tire
