Physics Help
Old Apr 25, 2008 | 05:26 PM
MikeZ's Avatar
From: Granger, Indiana (Next to South Bend and Notre Dame)
Default Physics Help
Ok...so I'm doing a physics problem for homewrk and a part of this question I can't figure out.
A professional skier reaches a speed of 37 m/s on a 24 degree ski slope. Ignoring friction, what was the minimum distance along the slope the skier would have had to travel, starting from rest?
How do I get acceleration with gravity and the 24 degree slope?
Old Apr 25, 2008 | 06:55 PM
agentofdarkness's Avatar
Default RE: Physics Help
Instead of a skier going down a slope, turn the problem into a box down a ramp at 24 degrees. The box has one force acting on it, gravity straight down. Change your coordinate system for ths problem. The X-axis should be parallel to the ramp and the Y-axis should be perpendicular to the ramp. The force of gravity will be between the new X and Y axis. Split this force up into two components, one along the X and one along the Y. Do the trig to solve for the acceleration in the X direction. I think the answer is ax = 9.8*sin(24) but its been a year since I've been in Physics.
Old Apr 25, 2008 | 06:57 PM
DFour's Avatar
whats the skiiers mass?
Old Apr 25, 2008 | 07:01 PM
ORIGINAL: DFour
F = m*a
If you only need the acceleration, the mass does not matter. Every body feels the same acceleration regardless of its mass.
Old Apr 25, 2008 | 07:52 PM
MikeZ's Avatar
Thanks for the help, btw....you got nice hand writing
Old Apr 25, 2008 | 08:06 PM
ORIGINAL: MikeZ
Alot of people say that , but I don't think its true. No problem. Is the answer correct?
Old Apr 25, 2008 | 08:08 PM
rangerscott's Avatar
ORIGINAL: MikeZ
Lets keep on subject tiger.
Old Apr 25, 2008 | 08:19 PM
Nauree's Avatar
U = K
mgy = 1/2mv^2
y = 1/2(37^2)/(9.8)
The angle of the slope doesnt matter with the conservation of energy formula.
Old Apr 25, 2008 | 08:29 PM
There are often many ways to solve a problem. I didn't think of using the conservation of energy. You will need to do mgh1 = mgh2 + .5mv^2. You will have to solve for h2 than use trig to find the distance. Probably the easier/faster way to solve the problem, but thats the first solution I came up with.
regener8ed
Nov 24, 2015 02:45 AM
rocketsauce035
Nov 20, 2009 01:10 AM
woo545
Dec 19, 2008 05:47 PM
specializedfuji
Apr 4, 2008 03:04 PM
