My lady put Unleaded Gas in the TDI (Diesel Fuel).....
Old Jul 15, 2011 | 12:22 PM
  #31
amRRussel's Avatar
Don't forget to make it look fancy...
Old Jul 15, 2011 | 12:36 PM
  #32
meggers's Avatar
Man I've gone tanning a bunch of times and it's not really working. hahahahahaha
Old Jul 15, 2011 | 03:03 PM
  #33
LetoCharles's Avatar
sorry guys i totally misread the 2011 as 2001. the 2011 is common rail and kiwi JK is correct, the common rails that have came in have been iffy, usually if they havn't been driven we can clear everything out and save them from having severe damage, if it was driven until it died, you will most likely be looking at pump and system damage.
keep us posted on what the dealer says.
Old Jul 15, 2011 | 05:20 PM
  #34
gump's Avatar
Sucks to hear. It warrants posting the set of photo's from your avatar.
Old Jul 15, 2011 | 05:36 PM
  #35
Dfbewley2's Avatar
I see your kitchen staff and Raise you
Old Jul 16, 2011 | 01:21 AM
  #36
thirdgenlxi's Avatar
Ironmang
Same with ours (I'm a Ford diesel tech).... we've had a few put gasoline in the newer 6.4's which use a high pressure common rail, and if you run it with gasoline it pretty much destroys everything in the fuel system. The diesel pump lubricates the high pressure pump so that seizes up, sends metal shavings through all 8 fuel lines and takes out all 8 injectors. Looking at many thousands of dollars for that repair on our trucks, lol. The older 6.0's and 7.3's though with the high pressure oil system, you could just drain/flush the fuel system real good and usually be OK
Hopefully there wasn't too much damage done.... keep us updated on what happens!
Old Jul 17, 2011 | 06:27 PM
  #37
amRRussel's Avatar
You know what is wrong with her/that picture right? It has nothing to do with kitchens or food
Old Jul 17, 2011 | 07:51 PM
  #38
Dfbewley2's Avatar
Enlighten me oh wise one!
Old Jul 18, 2011 | 08:33 AM
  #39
amRRussel's Avatar
It's not a real girl
Chew on that...
Old Jul 18, 2011 | 10:30 AM
  #40
__Z__'s Avatar
April 2011 Ride of the Month
I wanna be a REAL BOY
