Fish tank / Aquarium Guru's
RE: Fish tank / Aquarium Guru's
^ Best way to cycle a tank is to get RO water and let it run with a filter for a few days to a week. That will build all the beneficial bacteria and microbes you need.
I keep cichlids myself....well, and an angel (20g) I've had for years. The cichlids I have are Blue Reef Afras (cynotilapia afra-blue reef) and Yellow Labs (labidochromis caeruleus). I used to have some demasoni but the blue reefs killed them all, I hope to have a species tank of them one day, maybe with yellow labs too.
Here are a few pics of my tanks, I built the backgrounds in both of them (although the 55 gallon one had to come out, I'm planning another one). I also built the 55 gallon stand and canopy, but I didn't save any money...it was expensive to build too. Over engineered though.
20 gallon
55 Gallon just starting to cycle...no fish or plants yet
Aged with fish and plants (most of these fish are dead by now, these fish are really agressive towards each other, I may have one or two left)
20 gallon
Saltwater tanks are easy if you don't overload them. Lights are expensive, you need them for corals and some invertabrates, skip them in the beginning, stay with the cheap strip lights for now, just keep fish.
A wet/dry filteris a must. A protien skimmer is important, but can be added later.
As JD said, use 'cycle' and get cheap damsels or something. Even Black mollies may survive in full salt while the tank cycles.
You will have to ground the tank to reduce lateral line disease (cheap).
Don't put the tank too close to a wall, the salt may stain the wall over time. Maybe try and solve that problem ahead of time.
Avoid fish that only eat live food.
Saltwater tanks aren't hard at all, they just cost more money.
RE: Fish tank / Aquarium Gurus
ORIGINAL: Martin_D
How did you build the backgrounds? They looks awsome!
ORIGINAL: fishfryer527
A wet/dry filter is a must. A protien skimmer is important, but can be added later.
[blockquote]quote:[/i]ORIGINAL: fishfryer527 A wet/dry filteris a must. A protien skimmer is important, but can be added later. [/blockquote]
I'm sorry but I'm going to have to disagree with this statement. Wet/dry filters are junk and should never be used if possible. Do they filter the water? Yes, but they also produce a lot of nitrate in the system which will give you tons of algae problems. A good protein skimmer and a bag of carbon will be all you need for a salt water tank.
Never heard of it so I just did a search... Not really sure how it works. "Removes Toxic Elements - Including Copper & Phenol" I'm kinda curious as to how it removes them... You can't just add it to the system and the toxic elements just vanish all of a sudden. My old job I worked at a strictly reef aquarium store and the owner was a marine biologist. All of our tanks there were set up with sand, live rock, proper lighting, water taken from the ocean (I live near the beach), big protein skimmer, bag of carbon nothing more. With the reef tanks we had to measure ammonia, nitrate, nitrite, calcium, ph, and salinity and adjust the individual levels accordingly. But with a proper setup the ammonia, nitrate, and nitrite should always remain at 0ppm. We would add kalkwaser through the auto-topoff setup we were running which kept the calcium and ph where they needed to be.
All that with a few little water changes here and there to replenish the trace elements and the tanks were doing well. There are other chemicals out there besides kalkwaser, but that is what he decided to use for the tanks. There are too many ways to get a reef tank up and going... If there was one way and one way only to have a great tank that would make things so easy, but there are tons of different variations out there. The majority consist of 1"-2" deep sand bed, at least a 1/3 of the overall volume of the tank consists of life rock for biological filtration, a good sized protein skimmer to remove waste, proper lights for the corals you want to keep, and enough water circulation via power heads. Everyone however has their own chemicals they add to the tank and swear by, while others will say that stuff is junk. Get the right equipment the first time, and experiment with the additives to see what works out best for you.
