Big Feet??
I have an 03 600rr and i wear size 16 shoe and its not impossible but it is a challenge too shif gears...Does anybody else have the situation i do?? i was hinking adjustable rearsets or just cutting the gear shifter down but idk yet...Any suggestions??
Guest
Posts: n/a
Dunno if you know this, but if you loosen the two retaining nuts (one on each end) of your connecting rod on the shift lever you can adjust it up and down a ton, just spin the rod. If you have a hard time getting your foot under it you can raise it quite a bit. If that's not your problem you can pick up some adjustable rearsets, but they are spendy.
