New here
Old May 31, 2023 | 02:54 PM
Keiichi18's Avatar
Default New here
Welp finally bit the bullet and joined a forum all about the Honda CBR, don't normally join these things but heck its a nice bike and holds a lot of first time biking memories for me.
My Honda CBR125 RW7 registered in 2008 and I'm its 9th owner I think but thats neither here nor there.
Though I've had to stop riding it as for some reason she just won't start, and about 99% sure its the carb with the choke broken and seized in so I also want some help getting it back up and running as well as we can.
Old Jun 1, 2023 | 12:09 AM
dannoxyz's Avatar
Greetings & Salutations!!
That's nice bike.
As test, squirt about 2-3cc petrol into airbox, wait 30s, then start it. Does engine fire up? If so, you've confirmed fuel-delivery issue.
Old Jun 1, 2023 | 03:22 AM
Keiichi18's Avatar
That's nice bike.
I've done all that and the carb it actually out the bike but believe it or not the bike starts when you put fuel directly into the spark chamber but won't keep going after that fuel is burnt up
Also that choke cable there is completely seized into the carb there
Old Jun 1, 2023 | 06:40 AM
Welcome to the forum, good luck with the carb re-build.
Old Jun 1, 2023 | 03:43 PM
rockpool's Avatar
This one doesn't look much better - but maybe you can make a good one between them? https://www.ebay.com/itm/16569766702...Bk9SR9TVkYuPYg
Old Jun 1, 2023 | 10:53 PM
dannoxyz's Avatar
Lots of corrosion on that carb. Spray PB-blaster and let sit overnight. Then scrub with wire brush to remove as much corrosion as possible. Wipe off and spray PB-blaster again. Repeat until all corrosion is gone and you can operate choke cable again.
Most likely this carb will need complete disassembly for restoration, not just "cleaning".
Old Mar 21, 2024 | 12:50 PM
VictoriaDi's Avatar
EzElzz
Jun 24, 2012 02:09 PM
cherrios
Feb 19, 2010 07:24 PM
Cyber
Mar 9, 2008 11:40 AM
akcbrf3
Oct 24, 2007 11:40 AM
