intro and questions
Old Jun 15, 2013 | 09:53 PM
kamkam530's Avatar
New Member
Default intro and questions
hi, my name is kameron. i bought a 95 900rr as my first bike. it was a stunt bike so i got it cheap. so far i have not had any issues until now. i let somebody ride it and it started fine rode fine... until the tried to start it back up at the gas station. when he put the key in and turned it nothing happened. it seems that there is no power running at all. if anybody has any suggestions on what i can check to fix it all are welcome. i need to fix this asap and cheap. money is tight and in 3 weeks i will stand discharged from the corps and will be riding home from sc to ca.
Old Jun 15, 2013 | 10:09 PM
74demon's Avatar
Welcome to the forum and congrats on the bike!
When you say "nothing," do you mean no power to the dash on anything? If so, check your battery and cable connections. After that, check your main fuse.
If you have some power, let us know what happens in better detail.
Good luck with it...
Old Jun 15, 2013 | 10:14 PM
RydnaCBR's Avatar
Welcome to CBRF...
Old Jun 16, 2013 | 12:46 PM
Conrice's Avatar
welcome to CBRF. i echo demon's advice - check your battery connections, check fuses.
Old Jun 16, 2013 | 01:05 PM
kamkam530's Avatar
New Member
All battery terminals are connected. I get no power to the dash and the bike makes no effort to turn over
Old Jun 16, 2013 | 04:04 PM
Sebastionbear1's Avatar
Welcome to the CBR Forum Kameron,
If the battery is good - and check that it can be charged, next as Demon says, is the main fuse. There should be a downloadable manual for the 900 on the site.
Cheers, SB
Old Jun 16, 2013 | 06:30 PM
kamkam530's Avatar
New Member
where would i find the downloadable manual? also i just tried the battery out by simply attaching cable and trying to arc it, it was dead. however i still whent ahead and tried to jump the bike and even though i was connected to a pickup i still had no power to the dash or attempt to turn over.
Old Jun 16, 2013 | 06:43 PM
kamkam530's Avatar
New Member
i tried out the battery by arcing wwith some jumper cables, nothing. so i tried to jump it. even while connected to another vehicle there was still no power to the dash and no attempt to turn over. where can i finf the main fuse? and where can i download the manual from this site?
Old Jun 17, 2013 | 02:57 AM
wheelnut's Avatar
Welcome Crew
hi and welcome
manual download
https://cbrforum.com/forum/general-t...-here**-46596/
i think the main fuse is on the starter relay by the battery
berga1
Oct 8, 2009 11:07 PM
Clos
Aug 30, 2009 08:10 PM
TigreST
Jun 22, 2008 08:55 AM
Hollyworth
May 23, 2006 08:27 PM
revs
Aug 3, 2005 01:49 PM
