Thermo Fan Fuse
Thermo Fan Fuse
Riding around tonight,40-50 km runaround,could feel the Heat from the donk when i pulled up to put it away.
Watched the temp gauge go past halfway,usually the fan kicks in.......
fuse was Blown,second one in prolly 3 years.Any other Supersporters had this happen or is it just a case of poorly made fuses?
Interested to see what the other Aussies come up with...
on
hmmmm ...bit strange .........check your electrics .......regulator.rectifier and battery
& acid levels ........when the R/R goes wonky funny chit can start happening
I 've strated using these "when she blows she glows fuses" kinda cool they lightup
when they chit the bed .........nice in the dark
I use the old school method of "when she blows she glows".
That's when chit melts and catches on fire cuz I'm using 30A fuses...
(also easy to see in the dark)
That's a good point, tobiahr. Could be windings or the bearing.
I would still think it would do it more often, though....
A clamp on DC ammeter should be able to tell you the amperage draw but many of the DC ones are kind of expensive.
The other way involves adding a shunt resistor and checking voltage drop, but I don't know if it would be worth it.
Hmmmm.........Fuse #3 has blown,so there is definately an Issue with the Electrics.The battery isn't that old,top Quality.
Where does one start looking?
1.Fan motor,fan switch so the Haynes manual tells me........
2.Pulled the fairing off,checked for loose ,broken wires.fan turns easily no resistance.Warmed the bike up-you guessed it the Fan came on!WTF?Didnt blow the new fuse either....??
Im thinking that when the muppets did the chain /sprocks they may have hit the Fan switch/wiring when putting the fairing back on,seeing its in the right place to be hit.They did a crap job with the rear end so it wouldnt surprise me realy.
