ratticane lives
Hey there Gary , welcome to the forum
Looks like you got yourself a nice little number there and if it's in one piece , a bargain to boot.
The plastics can be repaired , Bluebeard busted his up pretty good in an argument with a tree , but he's put them back together and they look good judging by the last pictures he posted Do a search it might inspire you
I'm thrilled she rides it so much, I wave goodbye each morning as she takes it to work! Bought an 87 parts hulk for the front wheel, basically a rolling chassis with a butchered frame. It has brakes, forks, h-bars, controls, still in the van so no pics yet. I am Jonesing for the manual to show up. Thanks for all the encouragement. I am going to go look up Bluebeards plastic puzzle saga. This sounds like a bad case of scope creep and I'm only three days into it. I like the international flavor here, beer from around the world.
Workshop Manuals:
http://blackbears.ru/index_en.php?get=manual 600f-1000f 87-96
There are other links if you get stuck
If you need help with the plastics diagram - try
www.mrcycles.com
Heres my latest on Ratticane. One of the radiator end caps is leaking, has anyone repaired theirs? Aluminum solder? When I apply the rear brake firmly but not skidding the rear end jinks left. No issues on, off power just with the brake. On the center stand no obvious looseness or slop anywhere, any idea? what is acceptable run out on the front rim? The one on there is bent. bought a hulk chassis and it apears that wheel isn't the greatest either. Related; anyone have the front wheel bearing size? Finally I am trying to get a handle on the acceleration, it hits a lean (I believe) spot between about 7 and 8 I can nurse the throttle through it then it runs 8 to red line fine. I saw mentions of a 5K flat spot but this seems higher, then again idle shows 0 RPM on the tach so maybe it is the 5K flat spot. Not sure I saw an answer for that. V&H full pipe, oiled K&N in the stock airbox. 107.5 mains, one aluminum washer under the needles. I did not check the low speed jet size the idle screws are 2 1/4 turns out, it idles great and is pretty good everywhere but that flat spot. Hard copy of the 87 factory manual is on it's way. If I get my old sheet fed scanner going I might even attempt to scan it in.
