She lives again...finally
So I got her to start up today. All I did was use a homemade external tank, as I thought the fuel valve might be wearing and not allowing enough fuel to pass through when activated. She starts right up, mumbling for a bit til she warms up and is running 'okay' with choke off, got my idle at about 1200. I put the tank back on and she starts right up again, so I ride around for 5 or so minutes then stop cuz I have class. Got back a while ago and started her up again with choke, warmed up a bit, so i turned choke off and do a couple circles in the parking lot again. Then she starts getting weak right as I give her some throttle (which should be around 2500-3000 maybe) so i park it and it dies. turn choke on and it starts up, sits at 2k for a bit, then slowly starts going down until she dies again and won't start back up. So I still think it could be the fuel valve, but thought you guys might have a lil more insight.
So I guess the question is, how long can a bike run on whats already in the carbs+a little bit more(because I know the tank is providing SOME fuel at least) and do you guys agree that it sounds like the fuel valve? Thanks
PS sorry for the novel
So yesterday I had some time to work on the bike while the maintenance guys were sucking the water out of my apartment Water heater blew upstairs. Anyway, I pulled apart the petcock and snapped a few shots of the innards. Nothing special but f#%* it. Here's after you take out the 4 screws that connect the diaphragm to the petcock itself in the order they go
Not the sides of the rubber folding up, and the other side was disentigrating, so I put a new diaphragm on order thru bikebandit.
Took a little time to clean out the tank. This is just temporary, as I'm planning on trying out the KBS system sometime soon, so don't heckle me. First shot is fuel after draining straight out of tank
Next is after running 10 nuts thru it with some fuel a few times with some serious shaking. If you do this, all i can say is keep track of how many nuts you put in there
Pretty disgusting I know. last thing, I meant to take pictures of the inlet screen, but completely forgot before I put it back in. All I can say is keep an eye on that rubber bit that sits in the middle. Mine was all sorts of crooked. took me a bit to straighten it out.
