Critique Sought For Keyless Ignition Idea
After my recent ignition failure 3 hours from home that resulted in me taking a steak knife to my wiring loom i have decided to go for a keyless ignition switch. It will work out cheaper than a lock set and be a bit fun too.
I have ordered a rfid module and a latching relay. The idea is that I will swipe a keyfob over a part of the cowl (not sure where yet) and that will turn the ignition on, repeat and it turns the ignition off.
My thoughts so far.
Wire the fan to the Battery wire (red) before the relay so it has power available permenantly as I know that the engine temp briefly rises after stopping before it falls. I would like the fan to remain on for a short time after the bike is stopped and turn off when the thermo switch registers that it is cool enough like many modern bikes.
Dont bother with the park lock setting cause Ive never used it (has anyone else?).
The latching relay will connect Ign (red/black) with Batt (red).
Tl1 & 2 will be joined.
Looking for some constructive critisism. Anything jump out at you as being not OK or not the best idea?
Thanks in advance
Regards
Damian
My thoughts so far.
Thanks in advance
Regards
Damian
The down side is, you will have to post a how to when finished.
2102T Directed Electronics Passive Keyless Entry System | eBay
If the RFiD module wasn`t too expensive I`d consider using this, or some equalivent, as the main circuit instead so you don`t have to have a receiver in the fairings to sweep the fob over, all you need to do is walk into the proximity of the bike and it will recognize you without ever touching the fob. You`ll get the blinkers to flash as an indicator too. My keyless ignition system is based on that circuit but it has been modified with an extra board to fit the purpose better and make it a bit smarter. You also should consider converting your engine kill switch into a kill-everything switch or you won`t be able to shut down the power without sweeping the fob/walking away. My system works so that first I walk to the bike and get recognized, then make sure the engine kill switch is at ON position, pull in the clutch to wake up the power and start.
And no I cannot provide a wiring diagram/parts layout/board schematic as I bought it from this one chap that makes them over at a Triumph forum, although he can make one to fit any bike that hasn`t got a factory immobilizer.
I am definitely keeping the mechanical steering locking mechanism. What I meant was, when the steering lock is on and the key is in or out, there appears to be the ability to leave your park lights on (Aust model). That is something I have never used so am not planning to keep.
Cheers
Damian
Keyless systems on cars easily hacked, researchers say | Computerworld
Once the system is up and running i am going to put a disc in the right cuff of my jacket. They are plastic and about the size of a 20c coin. I will still keep the fob with me on my house keys incase my jacket is stolen by monkeys.
woot
08-20-2009 08:51 PM
