How To's Show us what ya did and how ya did it!
Installing H-4 Bulbs
Old Jan 15, 2011 | 06:57 AM
TimBucTwo's Avatar
Default Installing H-4 Bulbs
(1) Flatten the upper tab at 12 o-clock with pliers to widen it. The old bulb is a little wider.
(2) Push the two **** at 6 o-clock back flat against the body with pliers.
(3) Cut a piece of wire coat hanger the width of the body diameter and place it behind the body at 6 o-clock and bend the tabs at 4 o-clock and 7 o-clock back with pliers locking the wire in place.
Attached Thumbnails Installing H-4 Bulbs-bulb-1.jpg   Installing H-4 Bulbs-bulb-2.jpg
Old Jan 17, 2011 | 04:50 PM
Sprock's Avatar
.......epic.......
Old Sep 12, 2012 | 06:48 PM
Sharkmeat's Avatar
Registered Users
Default So, is that it?
I mean, is there any other changes, relays needed, or is this just plug and play. What I'm wondering is if the H4 bulbs draw the same amount of current as the stock bulbs. Or, do you have to make sure you get H4 bulbs with the same Watt rating, if there are different ones available???
And, for those who have done this, is it a notable improvement in the amount of light output compared to stock?
Sorry if this is a silly question...
-Mark
Old Sep 12, 2012 | 10:22 PM
kilgoretrout's Avatar
Administrator - Retired
Hey, I remember this thread.
I can't believe I didn't post "Nice one, TBT".
So I'm doing it now.
Very nice, TBT.
Old Sep 12, 2012 | 11:38 PM
Sharkmeat's Avatar
Registered Users
Ok, sorry. Thanx just the same.
Old Sep 13, 2012 | 11:02 AM
TimBucTwo's Avatar
The factory bulb has a "P43T" base. You can't just walk into any automotive store and get one and if you find them they are most likely 60w/55w. You can however get bulbs in "H-4" base in any store. There are plenty to pick from and have a wider verity of wattage. This is a way to adapt the "H-4" based bulb to the "P43T" reciprocal in the bike. It is plug and play after that.
Old Mar 3, 2013 | 09:23 PM
Insan3Nightmare's Avatar
Default ZxE silverstar
The ZxE silverstar bulb that I got from a auto store is amazingly white and bright. White lines on the road are very white now haha. Had to modify the "tit" to get them to fit but that's all. Worth the extra money.
Old Mar 6, 2013 | 06:45 AM
ranchome's Avatar
I had tried silver stars on another bike and was out off by the brightness of the reflective road signs.
Proved to be more of a distraction than the benifit of a little further cast.
I find the stock headlight setup on the CBR1000F quite good! Best headlight of any bike I've ever ridden.
Old Mar 13, 2013 | 03:02 PM
slowpoke's Avatar
I used this similar adapter years ago. H4 Bulb Adapter Rings Honda CBR900RR CBR 900RR RR CBR1000F 1000F Hurricane | eBay. You cut off the H4 lower tabs and place this adapter on the bulb so it fits. The truth is, once you cut off the lower tabs and place the bulb in the Honda socket, the springy thing is so strong it holds the bulb in place, even without an adapter.
Old Oct 3, 2013 | 10:33 AM
cubetop's Avatar
Thanks for the link! I just ordered a set for myself! I learned something new today!
Grafx
Aug 3, 2010 05:53 PM
sonyab523
Jun 19, 2008 05:20 PM
bboi
Apr 22, 2007 11:17 PM
steve00ses
Mar 30, 2006 02:13 PM
