How To's Show us what ya did and how ya did it!
Front Wheel Bearings - Replace - CBR1000F
Old Aug 29, 2012 | 02:43 AM
Naga_Thai's Avatar
Default Front Wheel Bearings - Replace - CBR1000F
Front Wheel Bearings - Replace - CBR1000F (There are many great videos on Youtube, but this is CBR1000F specific and may be helpful to first timers - and an alternate view for those who have done it before).
Download document (many quality pictures ) from link below [16 pages may take some time depending on your internet service].
Additional notes to workshop manual and attached photos..
1. Buy quality bearings (Made in Japan – not China [‘All *****” are Chinese]]
2. PLACE BEARINGS IN FREESER FOR AT LEAST 4 HOURS (OVERNIGHT FOR ME) TO ASSIST IN FITMENT.
3. Remove front wheel – bike on centre stand and then use pit lift or jack under motor to raise front wheel.
4. Place some plastic wedge between brake pads to avoid inadvertent operation. (Good time to check pads for wear).
5. Use a Rubbish bin as a suitable table to work on wheel.
6. Page 11. Looking at the bike from the front – there is the LARGE spacer on your RIGHT. Remember when replacing.
7. Page 12. Looking at the bike from the front – there is the SMALL spacer on your LEFT. Remember when replacing.
8. Page 13 – 14. Both bearings were replaced – one was OK but the other was very “notchy” and grated when rotated in the hand. The bearing seal has been removed for illustration only. [ Before bearing replacement - when the bearings were tested on the bike - no wear or grating could be felt when the wheel was rotated.]
9. Page 15 - 16 – good time to check your disk for serviceability thickness – must not be less than 4mm (just made it!)
10. Replace with new bearings and use old seals.
11.Your done! Have a beer and go for a ride!
http://dl.dropbox.com/u/13500879/Fro...20CBR1000F.pdf
Old Aug 29, 2012 | 06:00 AM
Sebastionbear1's Avatar
YOU are on a roll Naga - pun intended!
Another excellent "How To"
Well done.
Cheers, SB
Old Sep 5, 2012 | 06:39 PM
Hueristic's Avatar
What are the symptoms of needing new bearings? The same as a car? Or is it time sensitive or mileage based?
Old Sep 7, 2012 | 12:32 PM
Sprock's Avatar
Simple a very squirrely and non precise feeling even in a straight line
My 93 needs a set soon - I cheaped out the last time and Naga is right - buy JAP
Great write up btw
11 tho to be pc - might be have a ride go for a beer jk
Old Sep 7, 2012 | 02:12 PM
Naga_Thai's Avatar
Thumbs up
Go Sprock!!! Ya got the deliberate mistake!!!
Old Sep 9, 2012 | 02:07 PM
Sprock's Avatar
hee hee - a speed trap I did not see - now that's new .
One thing Naga - those Jap bearing part numbers - care to share ?
Old Sep 9, 2012 | 04:13 PM
Naga_Thai's Avatar
hee hee
Sorry Sprock - I thought the part numbers came out in my photos. The part numbers for front bearings I use are "6004-2NSE9" made by NACHI. <From your prompting I have also added this to the write-up. Thanks. >
Whilst your buying them why not buy these at the same time.... Rear Wheel Bearings - QTY 1 of 6305-2NSE9 & QTY 2 of 6304-2NSE9 made by NACHI.
FYI in $US .... about $45 for 5 bearings is what I pay here from local bearing shop.
Attached Thumbnails Front Wheel Bearings - Replace  - CBR1000F-imag0443.jpg   Front Wheel Bearings - Replace  - CBR1000F-img_5044.jpg
Old Sep 9, 2012 | 05:41 PM
Sprock's Avatar
Thx Naga - Found a good source here
USA Bearings & Belts
and even better Pricing and selection
Bearing Depot
Old Sep 9, 2012 | 08:29 PM
Here is a cross referenced list of available front wheel bearings for the CBR1000F
Not 100% sure it is for the '87/'88 but is for the Mark II '89/'91
Designation Manufacturer NSK RHP Basic Dimensions Type/PartNumberNote AuxiliaryPartNotes Designation E/A Designation E/A d D B or T
6004 *** 6004 E A 20 42 12 Single-row deep groove ball bearing, open type
6004 KOYO 6004 E A 20 42 12 Single-row deep groove ball bearing, open type
6004 NACHI 6004 E A 20 42 12 Single-row deep groove ball bearing, open type
6004 NTN 6004 E A 20 42 12 Single-row deep groove ball bearing, open type
6004 SKF 6004 E A 20 42 12 Single-row deep groove ball bearing, open type
6004-2NKE NACHI 6004VV E A 20 42 12 Single-row deep groove ball bearing, non-contact sealed type
6004-2NSE NACHI 6004DDU E A 20 42 12 Single-row deep groove ball bearing, contact sealed type
6004-2RS1 SKF 6004DDU E A 20 42 12 Single-row deep groove ball bearing, contact sealded type
6004-2Z SKF 6004ZZ E A 20 42 12 Single-row deep groove ball bearing, shielded type
6004.2RS KOYO 6004DDU E A 20 42 12 Single-row deep groove ball bearing, contact sealded type
6004.2RSR *** 6004DDU E A 20 42 12 Single-row deep groove ball bearing, contact sealed type
6004.2RU KOYO 6004VV E A 20 42 12 Single-row deep groove ball bearing, non-contact sealed type
6004.2ZR *** 6004ZZ E A 20 42 12 Single-row deep groove ball bearing, shielded type
6004E INA HR6004 A A 20 42 12 Single-row deep groove ball bearing, open type
6004H INA 6004-H- E A 20 42 12 Single-row deep groove ball bearing, open type
6004H 2RS INA 6004-H-DDU A A 20 42 12 Single-row deep groove ball bearing, contact sealed type
6004H 2Z INA 6004-H-ZZ E A 20 42 12 Single-row deep groove ball bearing, shielded type
6004LLB NTN 6004VV E A 20 42 12 Single-row deep groove ball bearing, non-contact sealded type
6004LLU NTN 6004DDU E A 20 42 12 Single-row deep groove ball bearing, contact sealded type
6004N *** 6004N E 6004N A 20 42 12 Single-row deep groove ball bearing, with snap ring groove
6004N KOYO 6004N E 6004N A 20 42 12 Single-row deep groove ball bearing, with snap ring groove
6004N NACHI 6004N E 6004N A 20 42 12 Single-row deep groove ball bearing, with snap ring groove
6004N NTN 6004N E 6004N A 20 42 12 Single-row deep groove ball bearing, with snap ring groove
6004N SKF 6004N E 6004N A 20 42 12 Single-row deep groove ball bearing, with snap ring groove
6004N+SP42 *** 6004NR E A 20 42 12 Single-row deep groove ball bearing, with snap ring
6004NR KOYO 6004NR E A 20 42 12 Single-row deep groove ball bearing, with snap ring
6004NR NACHI 6004NR E A 20 42 12 Single-row deep groove ball bearing, with snap ring
6004NR NTN 6004NR E A 20 42 12 Single-row deep groove ball bearing, with snap ring
6004NR SKF 6004NR E A 20 42 12 Single-row deep groove ball bearing, with snap ring
6004ZZ KOYO 6004ZZ E A 20 42 12 Single-row deep groove ball bearing, shielded type
6004ZZ NTN 6004ZZ E A 20 42 12 Single-row deep groove ball bearing, shielded type
6004ZZE NACHI 6004ZZ E A 20 42 12 Single-row deep groove ball bearing, shielded type
The primary dimensions are all the same. The main differences are whether they have plastic/steel or no covers on the side of the bearings.
Cheers, SB
Old Sep 9, 2012 | 08:35 PM
Sprock's Avatar
Don't forget German made wink wink
*** 6004's
