Trailer wiring turn signal integrator
So, I've been having some problems with this. I got the running lights and the brake light to work properly, but the two turn signals are acting funny. If I plug the turn signal wires into the proper positive wires on the bike side only running lights work. If I plug one turn signal lead the the bike's ground, while leaving the other on a turn signal positive, the grounded side through the integrator works, but the other doesn't and the brake lights work. I can get either turn signal to work in this fashion, but neither at the same time (even with brake pulled as in the above post). Any insight on this problem? I got the hopkins integrator (5 wires on bike side, 4 on the output side). Do these ones just not work? Which ones do work?
