How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
safety wire
Old Apr 10, 2008 | 09:08 PM
sandman889's Avatar
Default safety wire
Looking for help with step by step guide of what and how to safety wire my cbr 600rr for the track. Any and all help would be great. Thanks
Old Apr 10, 2008 | 10:30 PM
Jump1979man's Avatar
Default RE: safety wire
http://www.emra.ca/Tech%20Tips/Tech%20Tips.htm
Old Apr 11, 2008 | 06:34 AM
dwhite645's Avatar
Good link ^
The main thing for trackdays is to saftey wire the oil filler cap, oil drain plugandoil filter. Check with the track organization if there are others required.
Other good ones, like the article, are to safety wire grips, pinch bolts and radiator cap. Lastly, it's a good idea to get a castle nut on the rear axle (replace stock) and to run a large cotter pin through it and the axle once the axle has a hole drilled for it.
You can also saftey wire it by hand, without the tool. With ends of the wire in each hand, make it so theyform a90 degree angleapart and twist each tightly and equally together. The tool makes it easier, but isn't required.
Oh, and stick with .032 wire...thinner wire breaks easily if twisted too hard.
redzintimidator
How-To: Mechanical
174
Aug 8, 2014 01:07 PM
aight
May 1, 2011 02:05 PM
1000rrarmyguy
Jul 2, 2008 07:37 AM
tyler89
Dec 22, 2007 12:49 PM
sk8r20
Aug 29, 2006 01:08 AM
