How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
HOW TO: Wire Mesh in Fairings ('04 600RR)
Old Dec 27, 2011 | 01:21 AM
volcom440's Avatar
Default HOW TO: Wire Mesh in Fairings ('04 600RR)
Ok so to start off this is my first how to so its nothing super hard and it might have a little rough spots..
so to start off you'll need a few things
-Some type of wire mesh
-High temp adhesive ( i used Quick Steel)
-Scissors
-Clamps (optional but it seems like it would help)
-A little spare time
ok so in this how to im installing plain black wire mesh in these spots on my bike, both sides of course.
for the mesh i went to walmart and just bought a wire trash can, around $8 i think.
now to start you need to remove both side fairings by removing all the bolts, didnt take pictures of this because its pretty much common sense.
take your wire mesh (or trashcan ) and side it our for the hole on the back of your side fairings but leave enough room so you can trim up access and have enough on the sides for the adhesive to bond to.
next trim your mesh piece to size, and make sure that you get the fitment you want on both fairings and then start to prep your adhesive.
depending on the adhesive you buy dictates your next step, mine i had to combine the two compunds together and place them where i wanted. this is where the clamps would come in handy.
the mesh wants to come up off the plastic so i would recomend putting your adhesive down and then clamping it till it sets.
place the adhesive where you want it and start securing the mesh!
clean up any residue you have left over an make any final touches you want to make and stand back and admire.
when mounted these look AMAZING. and i'll post pictures of these mounted tomorrow if the weather is nice, bike is sitting in the garage for now.
before you put these back on i would recommend checking your coolant level as mine was low D: hoped someone got some help from my post. let me know what you think.
Old Dec 27, 2011 | 05:22 AM
zaqwert6's Avatar
Nov 2011 ROTM
Looks good. Couple of notes I'd add.
Make sure your plastics are super clean. Use some solvent everywhere you'll be using the epoxy or whatever. In fact you may want to even scuff the surfaces first to ensure a good bond. I've seen these mesh jobs come apart on the road and there can be dangerous results to you and your bike as well as the people behind you.
Also, you may notice that most of these types of mesh have a "grain" and generally it looks much better if you align that grain either with the lines of the bike and at least with the other pieces of mesh used on that side. Its just a cosmetic issue but once you notice it, you wish you did sooner.
Old Dec 27, 2011 | 10:49 AM
volcom440's Avatar
+1 on this, forgot to mention it in the original post but i took some 60 grit sand paper and roughed up where i was going to be putting the adhesive. and making sure the area is clean is super important or like zaqwert said... you'll have a projectile coming down the road eventually.
Old Dec 27, 2011 | 02:32 PM
zaqwert6's Avatar
Nov 2011 ROTM
Yes sir ,I was riding with a group a year or 2 with a someone who lost one of the screens and after it got done taking a ride around his back rim, scratching the crap out of it and the whole underside of his tail..... it took out the radiator of the bike behind him and right next to me. :O
Old Dec 27, 2011 | 03:36 PM
volcom440's Avatar
dammm. well i just went for a ride and got the engine nice and hot, they seem to be holding up pretty well, only time will tell though.
Old Jan 15, 2012 | 11:59 AM
volcom440's Avatar
still going strong, that quick steel stuff is ridiculous, had my mids off recently and that mesh isnt even close to coming off
Old Jan 18, 2012 | 03:04 PM
wbrevels's Avatar
looks good, I might have to do this to my new fairings before they go on the bike.
Old Jan 18, 2012 | 03:24 PM
volcom440's Avatar
thank you! its fairly easy. if you use the quiksteel stuff i would recommend that you keep mixing the putty together until it starts to get a little hot (heat comes from the chemical reaction of the two compounds) that way it starts to harden up and the mesh wont pull off of your fairing, but then again if you have clamps you wont have to worry about that
tricksta1984
May 28, 2010 11:20 AM
thecannibalchef
Jul 8, 2007 01:38 AM
D2VW14_20
Apr 3, 2007 09:45 PM
