Hotbodies Flush Mount FIX!
hey, so i started this up today and everything went perfectly (thanks to the super simple drawn diagram on page 2) for the left side. on the right i set everything up the same way, but i can't get a blink. it comes on as a running light, but simply goes out when i turn on the signal. i checked all my wiring (i think the green wire is the blinker, right?) and everything seemed nice and tight.
any ideas on what i did wrong for that side? also i'm having some trouble getting the front back on...are there any secrets to getting it to fit up right?
thanks all
thanks all
works like a dream with the diodes...... working on a plug and play box so both headlights stay on with low beam (high beam at about 40%) then both work 100% when on high.... will let you know how it all comes together. there will be no cutting factory wires.
Yes I would like to know hoe to wire the hot bodies fonrt blinkers to stay on. I also have an intergrated tail light. Tried wiring the front blinkers and the tail light would stay yellow, and front blinkers would not flash.
Haha after reading what I wrote kinda of wishy washy. Anyway I saw that video of the relay allowing the hotbodies blinker to be use as running lights as well as blinker usage. Can anyone tell me how to wiring a relay and what size relay I need for a 07 cbr 1000. Thanks
