How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
Convert 2 wire signals to 3 Wire Inputs
Old Dec 18, 2012 | 01:13 PM
  #161
Motleyfan's Avatar
March 2013 ROTM
Originally Posted by estate4life
Hey, post some more pic from different angle...bike looks good!
Not to hijack the thread but I have quite a few in the gallery section...
Old Dec 20, 2012 | 08:27 PM
  #162
Motleyfan's Avatar
March 2013 ROTM
Just made the 2 diode harnesses and installed them along with a LED blinker. Works great... Thanks again for starting this thread and the instructions.
Old May 2, 2013 | 04:25 PM
  #163
alikhad's Avatar
New Member
Just did this mod and it work PERFECTLY. Much appreciate the time and effort for posting.
I used universal lights that already had running lights (3 wire), but the running lights are blue and on the back to shine onto bike. I just tied the running light and signal light wire coming from the new blinkers (essentially turning them into a 2 wire system) and followed the instruction exactly as listed. Now my front signals are running lights (in my case both the front flasher - amber and blue lights on back). THANKS!!!!!!
Old May 26, 2013 | 10:54 PM
  #164
bigboi18184's Avatar
Appreciate the excellent How-To, previous owner had my front turn signals wired so the lights on the dash are always on.
Will be heading to Radio-Shack to get some diodes and fixing them thanks to this great write up.
--- worked like a charm, dash lights now off.
Old Sep 12, 2013 | 06:07 PM
  #165
02-F4i-SuperKax3's Avatar
All ways on when use the signals flash really fast
Old Sep 12, 2013 | 09:35 PM
  #166
I did everything you said and the light stays on then blink really fast
Old Sep 14, 2013 | 07:59 AM
  #167
Motleyfan's Avatar
March 2013 ROTM
Sounds like something isn't made correctly. Did you add the LED flasher unit? That will slow down the blinking rate.
Nick
Old Sep 15, 2013 | 07:22 AM
  #168
I just went and got one going to try thanks
Old Apr 1, 2014 | 12:20 AM
  #169
Weish's Avatar
So the running light shuts off once the blinker is turned on right? And then turns back on once blinker is cancelled. So my question is, why do you need 4 diodes? Wouldn't putting a diode just on the turn signal wire to restrict back flow of electricity to gauges work? Then you would only need two diodes. Anyone have any ideas?
Old Apr 1, 2014 | 08:19 PM
  #170
Wranghondo's Avatar
I did it the way redz shows how to do it and it works just fine. I see no reason to try and find a short cut.
