Wiring Problem?
Old Apr 5, 2007 | 08:15 PM
95camaro01f4i's Avatar
Default RE: Wiring Problem?
well i get my front fairing back hopefully monday and get my bike back together ill let you know how i make out
Old Apr 5, 2007 | 11:56 PM
SomeName's Avatar
ORIGINAL: 95camaro01f4i
somename did they tell you what pin?? what it the ground wire pin
No, they just told me that it was one of the connectors from the main wiring harness.
Old Apr 6, 2007 | 12:14 AM
well i know when i take the front fairing off and put it back on every thing is okay. which is what makes it hard to find the problem. lets hope they fixed your problem. pm me if it comes back
Old Apr 6, 2007 | 04:09 PM
SomeName's Avatar
I have it back now & I rode it for like an hour yesterday... everything seems fine (knock wood)...
Old Apr 6, 2007 | 04:44 PM
mine was like that 2 i thought i had it fixed and then like 1-1 1/2 months later it came back.
Old Apr 10, 2007 | 03:28 PM
suicidal's Avatar
i fixed my problem by getting new upper sub-harness and headlight relay. seems to be workin fine now.
Old Apr 12, 2007 | 04:04 PM
the problem is deffinetly in the plug coming from the head light assembly to the main harness.every time the problem comes up i jiggle the plug it goes away.
the correct fix for this is to replace the bad pin in the plug.
but a quick fix we did and should be done to all the plugs on the bike is to clean the terminal with a cleaner from you local parts store to clean electrical plugs. then we put in each plug electrical continuity grease this will keep water and corrosion from geting into you plugs. i dont know why but these plugs honda used do not look water tight so i would recomend using the grease in all you plugs. you can get all the stuff needed ay your local auto parts stores
lilbushhead
Apr 1, 2010 11:50 PM
tuai rumah
Jan 13, 2009 07:34 AM
HAVOC
Jan 18, 2008 09:52 PM
TrnsferErr
Jun 4, 2006 12:31 PM
Kuczus
Feb 16, 2006 09:09 PM
