wiring problem, i need help.
Old Jan 9, 2009 | 09:21 AM
tuai rumah's Avatar
Default wiring problem, i need help.
recently,i install the undertailat my cbr 1000 model 2006. but my front and behind signal lights failure. even my hazard light also not funtioning. please help me .....
Old Jan 9, 2009 | 09:31 AM
CBRjosh1000rr's Avatar
Default RE: wiring problem, i need help.
You need to first take your left upper fairing off and check the fuses. Sounds like you grounded the wire and blew one. Second if that does not fix it just retrace the wires. Luckily bikes are easy to work on and fix.
Old Jan 11, 2009 | 05:47 AM
tuai rumah's Avatar
I had a mechanic checked it out, and turns out the fuses are fine. Could it be because of the faulty relay? The mechanic is ordering a new relay and i'm still waiting.
Another question is : why is my HISS not blinking? It is supposed to blink for 24 hrs. It started when i installed the undertail and the mechanic had to dismantle the wiring and later rewired the whole thing.
Old Jan 13, 2009 | 07:34 AM
tuai rumah's Avatar
Default RE: could be a relay problem?
lilbushhead
Apr 1, 2010 11:50 PM
HAVOC
Jan 18, 2008 09:52 PM
SomeName
Apr 12, 2007 04:04 PM
TrnsferErr
Jun 4, 2006 12:31 PM
Kuczus
Feb 16, 2006 09:09 PM
