Wiring gurus?
Old Jan 9, 2007 | 11:55 PM
Brandon77's Avatar
Default Wiring gurus?
Just finished putting in my rear peg LED signals, but messed something up when wiring them. My dash lights and brake lights will not light up unless I pull the brake. Help!
heres what I mean:
[IMG]local://upfiles/11313/ACBD5D33FBFB41F4933502C3B4A4C36D.jpg[/IMG]
[IMG]local://upfiles/11313/B0ECB2734B1E42638CEDB0198A0CD3A1.jpg[/IMG]
________
Bondage Cams
Old Jan 10, 2007 | 12:50 AM
dragonium25's Avatar
Default RE: Wiring gurus?
You most likely blew a fuse.
Old Jan 10, 2007 | 01:08 PM
D2VW14_20's Avatar
Did you connect your leds to the stock turn wires???? If you so, you mostly likely blew a fuse or have a short somewhere. Go back and make sure everything is connected properly and tightened down, and if so, you'llhave to check your fuses. If you didnt connect resitors, it could be a power draw too...... Just check all your stuff, and if it isnt a connection or a fuse, Idont know what then, because if you didnt mess with and of the front wiring or speedo harness, the only thing I could think of is a power draw. Abadfish seems to be very insightful on these topics so maybe you could PM him.
Old Jan 10, 2007 | 06:04 PM
Brandon77's Avatar
ORIGINAL: D2MEclipseGT_600RR
Yes I connected the LEDs to the stock signal wires, should I not have?
________
MC
Old Jan 10, 2007 | 10:40 PM
D2VW14_20's Avatar
Yes, atleast thats what I did. I was just saying IF you didnt, that may have caused some of your problems. Honestly, if you have checked everything above, I dont know what else. But like I said, email Abadfish and maybe he can help
Old Jan 10, 2007 | 10:43 PM
bobjoezx's Avatar
explain waht u did, also are your turn signals 2 wire or 3 wire, stock is 3 wire so you have to figure out if you want turn signals or running lights and wire them accordingly....
Old Jan 10, 2007 | 11:06 PM
D2VW14_20's Avatar
Rear only has 2 (atleast on 05-06)
Old Jan 11, 2007 | 12:13 PM
Brandon77's Avatar
my rear has 3, orange/blue, green, abd black. I checked the fuses and found out I blew one, so thats most likely the problem, ill get some fuses today and try it again.
________
spanish girl Cams
Old Jan 11, 2007 | 06:35 PM
Told ya
jpanside@gmail.com
Feb 13, 2014 04:45 PM
Kchadwick917
May 2, 2013 06:21 PM
jackojeff
Feb 27, 2013 09:03 AM
DarrylS
Feb 9, 2013 06:06 PM
TennesseeCBRF2
Jan 11, 2007 03:46 AM
