Wiring gurus?
Wiring gurus?
Just finished putting in my rear peg LED signals, but messed something up when wiring them. My dash lights and brake lights will not light up unless I pull the brake. Help!
heres what I mean:
[IMG]local://upfiles/11313/ACBD5D33FBFB41F4933502C3B4A4C36D.jpg[/IMG]
[IMG]local://upfiles/11313/B0ECB2734B1E42638CEDB0198A0CD3A1.jpg[/IMG]
________
Bondage Cams
heres what I mean:
________
Bondage Cams
RE: Wiring gurus?
Did you connect your leds to the stock turn wires???? If you so, you mostly likely blew a fuse or have a short somewhere. Go back and make sure everything is connected properly and tightened down, and if so, you'llhave to check your fuses. If you didnt connect resitors, it could be a power draw too...... Just check all your stuff, and if it isnt a connection or a fuse, Idont know what then, because if you didnt mess with and of the front wiring or speedo harness, the only thing I could think of is a power draw. Abadfish seems to be very insightful on these topics so maybe you could PM him.
RE: Wiring gurus?
ORIGINAL: D2MEclipseGT_600RR
________
MC
RE: Wiring gurus?
my rear has 3, orange/blue, green, abd black. I checked the fuses and found out I blew one, so thats most likely the problem, ill get some fuses today and try it again.
________
spanish girl Cams
________
spanish girl Cams
