where does the other side of the starter ground connect?
Old Aug 18, 2011 | 11:00 PM
alex59195's Avatar
Default where does the other side of the starter ground connect?
is it to the negitive side of the battery? or frame somewhere>
Old Aug 19, 2011 | 09:47 AM
shok47's Avatar
either one will work. You must find a section of the frame with bare metal. If there is none you can use a wire brush to take some off is need be. Battery (-) works to. The ground for the battery is the bike frame itself.
Theoretically the power transfer will be stronger if you do it directly to the battery, this way the electricity has the least amount of obstacles to travel through before returning to the battery.
cschew
Aug 21, 2013 01:13 AM
ekko
May 21, 2013 06:54 AM
coldflood
Sep 3, 2011 09:06 AM
schultzy
May 12, 2010 01:32 AM
