Soder Quick Connect
Old Aug 26, 2011 | 12:55 PM
coldflood's Avatar
Default Soder Quick Connect
anyone know how Read that its better than crimping in the stickied thread on the R/R's.
Old Aug 26, 2011 | 12:59 PM
herbcbr1000f's Avatar
um i have no idea what you just said.
Old Aug 26, 2011 | 01:03 PM
coldflood's Avatar
Read post number 48 https://cbrforum.com/forum/f2-tech-9...d-27739/page5/
he kinda slams crimped connections
Old Aug 26, 2011 | 04:35 PM
MadHattr059's Avatar
If you are refering to permenantly soldering the r/r to the harness, I would
recommend against it. If you are refering to how to attach the connectors to the
harness, than, "yes". Crimp and solder, is definitly better than crimping alone.
It's not hard, if you know how to solder in the first place. What I do, is
use crimp connectors that crimp on the wire and the insulation.
Crimp both and then solder into the wire crimp. Then pull the piece of
heat-shrink tubing down over your job and heat to fit.
If you look at this photo, you can see how it will look when done.
The bayonet connectors that I attached are on the left, in the photo.
Hope that answers your question, Ern
Old Aug 26, 2011 | 04:37 PM
P.S.
That black wire, runs up to the guages to power the clock for my
F3>F4i conversion. The white connectors are coming from the R/R
itself.
Ern
Old Aug 26, 2011 | 06:22 PM
coldflood's Avatar
Where do you find a connector that goes over the insulation?
Old Aug 26, 2011 | 06:30 PM
Not sure I understand the question.
Ern
Old Aug 27, 2011 | 12:29 PM
coldflood's Avatar
Also, how do you soder into the wire crimp
I've never heard of bayonet connectors
Old Aug 27, 2011 | 01:11 PM
tucsondude's Avatar
My post on another forum.
BMW 2002 FAQ - HOW TO fix a broken connector/make your own harness. 56k DIE
look for the picture that is labeled A B C.
you would crimp the insulation at A and wire at B
after you do that you would take a soldering iron at B heat it up, and melt solder into the wire.
you may have to recrimp at A since the insulation will like melt some.
do not get solder or have excess wire where the connectors connect.(C)
I would reccomend 60% lead, 40% tin for ease of soldering.
you should also file down the edge where the connector breaks off.
you can get cheap irons at the dollar store, however a major fire/burn hazard. Or this should be a great knockoff station (i have the actual HAKKO version)
Soldering Station-CSI-STATION1A
you tube and do some research on Soldering technique.
Old Aug 27, 2011 | 01:34 PM
coldflood's Avatar
cool thanks for clearing that up, was a bit confused at first.
