When to replace chain & sprocket
Old Dec 13, 2011 | 08:09 PM
  #21
Sprock's Avatar
Def not stock , if you pull the chain in the middle of the rear sprocket and it gives
more than 1/4 inch or more sprocket needs replacing and might as well go with a
kit as the previous good advice suggests
I always take the line with a bike where the maint' history is vague - replace these
major items - chain , sprockets , brakes & tires ... basically the stuff that saves your
life
imo chain and sprocket sets are good from 12 to 16k miles depending on how hard
the bike is ridden... myself I go about 12k and change ..... but it depends on brands
and material used - steel versus alum sprockets etc
my 2 cents
Old Dec 13, 2011 | 10:39 PM
  #22
estate4life's Avatar
February 2012 ROTM
46 teeth? Wow...I have never counted? But factory set up is 16 front 43 rear....if previous owner gone +3 on the rear? I wonder what front is? If I have time I'll take off the cover & check?
I wonder what is the real difference if I go back stock? I've been riding this bike for 4 years and love it...I really don't want any significant changes because I'm so used to this bike...
Originally Posted by zaqwert6
That number stamped into the rear sprocket is the teeth. Xxxxx-46. 46 teeth. Fyi.
Old Dec 14, 2011 | 02:00 AM
  #23
zaqwert6's Avatar
Nov 2011 ROTM
Well if the front is anywhere near stock then it should be a wheelie monster. But you need the front number for sure to figure the actual ratio. No telling what they may have done.
There are sites that will figure the differences for you. Used to be one called gearingcommander I think , if its still around, for example.
Old Dec 14, 2011 | 02:43 AM
  #24
gotama's Avatar
Here ya go
Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
Old Dec 14, 2011 | 09:11 PM
  #25
zaqwert6's Avatar
Nov 2011 ROTM
Originally Posted by chucks_net
doesn't look stock. May not be stock gearing judging by the aftermarket rear sprocket
This means the indicators on the swingarm mean nothing.
Possibly....
Originally Posted by estate4life
I notice chain slack need to be adjust every 2000miles maybe 2500....
Except it seems he's been adjusting for a period of time and have now, reached those marks, so probably still a pretty good indicator....particularly on aluminum sprockets.
In my case, as I ride reasonably hard, the rule of thumb I use is generally I replace 1 front tire to every 2 rear tires and 1 complete chain set to every 3 rear tires. I forever now dub that the "1/2/3 Rule". For me tire wear is more indicative of condition of the relative parts based on use then mear mileage alone.
YMMV Pun intended.
hurricanematt
Feb 26, 2011 08:02 PM
CarbonCBRF4i
Feb 17, 2011 03:30 PM
jwp6114
Aug 12, 2006 05:53 PM
ghostrider181
Dec 28, 2005 10:10 AM
