What's this leak?! Best guess?
Old Nov 4, 2015 | 02:13 AM
BlueBerryPie's Avatar
Default What's this leak?! Best guess?
Hi there.
My bike fell over about 3 weeks ago.
You can clearly see a leak from the tube, seems to leak fuel off and on every day or so, and I don't know what to make of what's caused this. So, before I take it to the shop... any ideas?
Many thanks, BBP
PS. Originally I tried posting this in the CBR600F4 forum two weeks ago but go no answers.
Old Nov 5, 2015 | 12:22 AM
Sebastionbear1's Avatar
If it is fuel - it's the overflow tube from either the carbies or the fuel tank. Trace it up and work it out. Dip your finger in the liquid and smell it - that'll tell you if it is fuel or not.
If it's the carbies, float height has been knocked out of adjustment by the tip over.
If it's the fuel tank, the vent tube may have split in the tank.
You need to trace the tube to its source.
If it IS fuel and it's leaking onto a hot exhaust this is not considered good for longevity, both the bike and yours!
Cheers, SB
Old Nov 5, 2015 | 02:53 PM
Hi.
Thanks for the reply.It is definitely fuel and it pools substantially when I refill it with more fuel.
So I traced it up to what seems like a little reserve chamber of sorts, and it appears that when the bike tipped over the impact somehow switched the fuel reserve petcock position to "on". I will check later to see if the leaking has stopped and will report back.
Thanks, BBP
Old Nov 6, 2015 | 12:04 AM
The tube goes to the fuel pump (fuel pump drain tube). I have confirmed the structure in the manual.
In other words I have a leak somewhere further up the tubes, perhaps the carbs. leaking down into the pump and it's going out the pump drain tube. I've turned the petcock to off position to stop the major bleeding but I guess I'll have to take it to the shop and have a pro go over it.
Thanks, BBP
PS any suggestions welcome.
Old Nov 6, 2015 | 09:22 AM
Thanks, BBP
Like what was stated earlier, my money is ona stuck float or a cracked t-pipe
skot
Oct 14, 2005 03:51 AM
clemson725
Oct 4, 2005 08:26 PM
osopolar
Aug 18, 2005 07:03 PM
Diesel
May 9, 2005 10:07 PM
