What happened to DOT 4 brake fluid?
I swung by Pepboys to pick up some brake cleaner and brake fluid. Planning to flush, bleed and deglaze the brakes this weekend. So on the fluid isle I'm looking for DOT 4 fluid and... nada. DOT 3 and this stuff
Says it exceeds DOT 3 and DOT 4 specs. But there was no plain ole DOT 4 on the shelves. Something change?
Welp here's why I was looking for brake fluid
No, that's not a urine sample. That was my old brake fluid.
The rear pads.
Flushed the old brake fluid, took my DA sander to the pads with 80 grit paper, put in new brake fluid, bled the brakes and cleaned the discs.
Went around the block to make sure everything was good and holy chit. Brakes tried to toss me over the bars, lock both tires and stoppie
The rear pads.
