What is this auto adjust chain?
Old Mar 13, 2007 | 02:53 AM
bmg velocity's Avatar
Default What is this auto adjust chain?
On my 94 600 F2 is supposedly a self-adjusting chain tensioner.
Never heard of such in my life.
I checked the chain...and it has the right amount of slack...and I know how to adjust the chain on a "regular" bike...
Simply get the rear wheel off the ground...lossen the axle nut...removing the cotter pin if any first...then the two side tensioners...
usually little 10mm bolts...that actually move the wheel back evenly....making sure each marker...on each side of the bike
line up the same so your wheel is straight.
But...again..."self-adjusting"?
That vacation I took from bikes from 94 to 2006 must have seen alot of...something.
Any advice...or info..appreciated...
Old Mar 13, 2007 | 03:18 AM
Default RE: What is this auto adjust chain?
BTW....I adjusted the chain manually myself as it was a bit loose...
Still curious about this auto adjust feature though...
Old Mar 13, 2007 | 03:40 AM
dragonium25's Avatar
Are you sure the 'self-adjusting' is referring to the chain tensioner, and notthecam chain tensioner?
Old Mar 13, 2007 | 07:05 PM
Bobthebiker's Avatar
I was thinking CAM CHAIN tensioner is auto adjusting, well the stock one is anyways. the APE one I've got is manual.
Old Mar 14, 2007 | 04:13 PM
richterat83's Avatar
The Honda Factory Cam Chain Tensioner is auto adjusting. The chain that drives the rear wheel is not
Tylor
the600
Sep 21, 2012 10:27 PM
mcastro253
Jun 5, 2012 12:19 PM
Omaha rider
Aug 3, 2011 02:35 PM
el-cid
Jul 11, 2011 08:50 PM
rogueelite
Sep 26, 2010 06:25 AM
