How often do you have to adjust your chain?
I have owned my 2000 F4 for less than 1500 miles now, and I seem to be having to adjust my chain VERY frequently.....like every 150-200 miles! It has a Non-o-ring chain (I am not sure if that was stock on these or not).... does that have anything to do with it? The chain was dirty and dry when i bought the bike, so I cleaned and lubed it right away, using Dupont teflon multipurpose lube. When I adjust the chain (to 1" deflection) it seems i can already notice it loosen a little even after the first 50 miles after adjustment! The teeth on the sprockets don't seem worn, and all else looks good......Any ideas, or is this normal? I am still new at this motorcycle thing!
Of course, if that's the original chain from a 13-year-old bike, it might be due for replacement anyway.
Sorry I took so long to reply...and thanks for the advise! If the sprockets look good, can i just put on a new chain? Or should i replace the chain and sprockets as a set? Also, if I am replacing only the chain, how can I be sure what chain to put on....because the previous owner said something about having changed the front sprocket...(one tooth down maybe?) Any advise on chain brands or styles for the "economy shopper"? Lol!! Thanks again!
my experiance, with good maintenance and normal wear, mine does that around the fifteen to twenty thousand mile mark and its time to replace it. i buy the sprocket and chain kit.
i just put a new chain sprocket kit on last week because it had the same symtom and it was time after sixteen thousand miles. i also replaced the cush drive damper set because it was worn (dry rotted,cracked and hardened rubber) and still had slop and was very jumpy during acceleration and deceleration, even after the new chain and sprockets.
i dont know how many miles are on your bike but, if and when you put a new chain&sprockets on your bike, check the cush drive damper set too. it can effect your chain and its tension, wear and tear, ect. your rear shock travel hieght and setting can effect your chain tension also.
for example, im around two hundred forty lbs, plus the twenty-five pound pack i haul around often. i set my back shock on five or six, in the stiffer,higher range. see, as the swing arm travels up and down when ya go over bumps, the chain slightly tightens and loosens. so, if you have it too tight to begin with, and you are a fat-*** like me, when you sit ur big *** on the bike and the chain is at one inch it may be too tight while riding and thats bad. i keep my chain at about an inch and a quarter play, on the looser side. if your a light weight do the opposite. manual says it needs to be between 1- 1 & 3/8.
i have learned a lot from people on here. i have my own procedure for chain and rear wheel maintenance...it takes practice to get it near perfect. take your time and learn. to make it easier you can get a chain alignment tool on ebay and look up chain alignment procedures on you tube.
some times im long winded but, i hope that helps. need any more help just holla
Thanks for the tip about the cush drive! I will check that out too! With the Ohio riding season drawing to a close......that sounds like a good winter project! Thanks for all the help! The bike has 22k on it, but not sure if the chain is original or not......I am assuming it is, because anyone replacing it would probably have replaced it with an O-ring chain....but you never know!!
