Waterpump insatll help
Old Apr 6, 2016 | 01:49 PM
MegatronousPrime's Avatar
Default Waterpump insatll help
Has anyone replaced their Waterpump on the F4? Is it pretty easy and straight forward? How do I bleed the air out? If anyone can help with instructions it ws greatly appreciated! Thanks guys!
Old Apr 6, 2016 | 10:01 PM
coalminer frank's Avatar
You need to get a F4 Clymer Manual or Haynes Manual or both. I got both for my F2, and the Honda Shop manual. Worth their weight in gold.
Old Apr 7, 2016 | 11:39 AM
Sam Scaife's Avatar
Smile hello
It is actually very easy and i removed mine to address a leak. Turned out it was a dirty gasket and one of the hoses leaked. I do not know the torque specs on the bolts but they are standard 10mm so roughly 7lbs pressure should be fine. Fixed mine a year ago with no leaks or loose bolts. Remember that you will need to have patience when refilling your coolant system and may have to fill cap then uncap and fill again till the fluids do not go down. The fluids part is the hardest part honestly.
J187
Jul 19, 2022 09:04 AM
Dan1220
Sep 21, 2020 10:19 AM
black93lx
Jun 23, 2007 02:27 PM
hill1513
Jun 13, 2007 05:13 PM
Dan1220
May 18, 2007 12:19 AM
