Variable drive chain tension???
Old May 30, 2009 | 11:41 PM
Timothy's Avatar
Default Variable drive chain tension???
I have a 1991 CBR600F2. It is impossible to adjust the chain. It varies from TIGHT to 1.5" of free play as you rotate the rear wheel. What does this mean? Must I replace the chain? If I do, must I replace the chain & sprokets as a set? TAI...
Old May 31, 2009 | 01:10 AM
justasquid's Avatar
generally, that means your chain is shot. If the rollers roll freely and there isnt a lot of side to side lash, you get away with just lubing the chain.
If the chain is found to be bad, replace the chain along with sprockets as a set. You dont want a new chain on an old set of sprockets.
How are you checking the tension? Is the bikes rear wheel off the ground? or is the bikes wheel on the ground?
Arthur48
Oct 24, 2016 06:59 AM
raj1976
Aug 20, 2009 05:26 PM
TweakedCBR929RR
Apr 14, 2006 02:39 AM
BlindLOKI
Mar 11, 2005 12:15 AM
BlindLOKI
Feb 18, 2005 11:48 PM
