valve question
Old Jan 21, 2009 | 06:38 PM
honda f4's Avatar
Default valve question
alright i just got my carbs pulled off to check my valve adjustment and as i looked into my ports where i
pulled the carbs off i see the bottom of my valves and they look gummed up almost like tar , should i be worried about
this before i adjust the valves or should i do all this work and put seafoam in the tank, will this take care of this???
Old Jan 21, 2009 | 07:52 PM
aj_jensen73's Avatar
Default RE: valve question
I dont know the answer to that but I am going to keep an eye on this thread so I can see what people are saying about it.
Old Jan 21, 2009 | 08:25 PM
honda f4's Avatar
ok!! somebody has to know help me out have you seen this i wouldnt think it would be a problem the pin is really
clean its just where the fuel comes in to go into the port to go to cylinder . i just need some reassurance
i havent done this before
Old Jan 21, 2009 | 09:32 PM
justasquid's Avatar
It depends on how tar like it is. there really shouldnt be anything on the carb side, the exhaust side there will be black build up, but not muchon the intake side. If there is, I would assume you might have leaking valve seals.
If its just carbon build up, its not really anything to worry about. Carbon build up is black, usually flaky. A Tar like substance though usually means oil.
Does it burn use any oil?
Can you see any blue smoke out of the exhaust?
How many miles are on the bike?
Old Jan 21, 2009 | 09:47 PM
krowles's Avatar
im going to say leaky valve seals, also have you done a comp test and a leak down test?
Old Jan 22, 2009 | 07:00 AM
honda f4's Avatar
ive got 35000 miles on bike , does not burn oil , exhaust is usually white smoke,
its moreliquidy than tar i could actually wipe off from port
this is the first time checking valves and going to clean carbs other than that
just standard oil changes and plugs but the plugs i have to change every year in spring
to get started than it runs good until fall when it gets cold , i live in michigan
Old Jan 22, 2009 | 06:08 PM
DWT74's Avatar
The intake valves will get a bit of soot on them and you may have spilled some gas on them taking the carbs off and it made the liquid tar/soot you are talking about. If its a large quanity then you got problems, make sure the air filter is cleanand anything downstream of them is clean and clear.
Old Jan 22, 2009 | 08:25 PM
honda f4's Avatar
thanks for the input everybody im going to adjust valves clean carbs syn carbs and use some sea foam in tank i
hear good things about this stuff might add to tank every oil change
JankCibberf2
May 11, 2011 11:04 PM
bundy26
Jun 21, 2010 10:16 PM
dyracuse
Feb 22, 2010 07:25 PM
honda f4
Jan 26, 2009 04:23 PM
Hurricane rider
Jan 9, 2009 03:38 PM
