Using current pads with new discs?
Old Oct 27, 2017 | 02:37 PM
Gunk's Avatar
Disc bolts are not designed to be reused, but everyone does.
Old Oct 27, 2017 | 03:27 PM
dec111's Avatar
Originally Posted by 74demon
Had to be a weak bolt, unless you really cranked down on it.
Yeah, it gave with very little force
Old Oct 27, 2017 | 03:29 PM
dec111's Avatar
I've no prob using them again, just want them screwed in so everything lines up as it should, considering it's the brakes like
Old Oct 27, 2017 | 04:42 PM
Gunk's Avatar
I use a dab of torque paint on all the caliper, disc and wheel nuts. It’s easy to do a quick visual check that nothing has moved.
Old Oct 28, 2017 | 09:15 AM
heresolong's Avatar
To get back to brake pads, I use emery cloth rather than sandpaper and I probably wouldn't use a file as it's hard to keep flat. No issues in my opinion reusing them.
Old Oct 28, 2017 | 12:09 PM
dec111's Avatar
Ended up using the pads that came with the discs, they're organic and def don't bite down as well as the sintered Brembos did, prob will stick new sintered in.
Old Oct 31, 2017 | 06:52 PM
SunBlue's Avatar
I've reused pads on a different disc, after a couple rides it felt the same.
I've got sintered pads on the front and organic on the rear, I figured I don't need all that stopping (ahem, locking) power on the rear...
Old Nov 1, 2017 | 01:48 AM
Rob2m's Avatar
Using sintered pads will cause more disc wear anyway. The harder the pad the less it wears the offset being the disc wears more.
Lorenzo Giccominato
Sep 3, 2015 06:50 AM
FLRider
Mar 28, 2011 07:10 AM
bigbloke
Apr 19, 2008 01:21 PM
chainstretcher
Aug 29, 2005 01:54 AM
