tyre issue
Just Bought new tires ( Metzeler Sport Tech M7RR )and less than 100 miles on them I get home to this split rear . Bear in mind I definitely did not run over anything or remove anything from the tire and this split goes all the way through the tire and takes less than 2 min to go flat, I haven't as yet removed the tire so I don't know what the inside of the tire looks like but in all my years of riding and driving I have never seen anything like this damage/defect in which there was nothing left embedded in the tire and no outline or marks of something having been embedded at some point. Out of curiosity has anyone else?
It sure has the appearance of a cut from the outside. If it was sharp and stuck to the ground I don't think you'd be able to notice it at any kind of speed. It just doesn't look like rubber separation, but a sharp cut.
Looks like sheer bad luck to me.
On the other hand, it could have been a catastrophic failure at high speed causing a lot more damage to the bike and possibly you as well.
Maybe incredibly good luck after all.
Its the fact that nothing was left imbedded in it and there are no marks or debris (rock or dirt) to show that anything ever was. I was "super lucky" that after a 2 hour high speed blast on very twisty roads this tyre started going flat less than half a kilometer from home on suburban roads and even then I had to stop halfway a service station to pump it up, lol.
My main concern is, do I replace the tyre with the same or go back to the Pirelli diablo corsa's I've done the exact same trip on for over 10 years without a problem or continue with the new Metzelers (whose grip level and feel are magnificent and better than the Pirelli's by the way) and risk this happening again in a worse place???
The only other thing I can think of, if you didn't run over something sharp, is if the bike was parked up, someone with a vindictive streak may have punctured the tyre. But if it wasn't left parked out of sight, that would rule that out.
If it starts to bother you Pirelli or any other big tyre manufacturer has similar tire as the Metzeler M7RR but to me it allso looks like you hit something rather than a defective tyre from the factory. I personally haven't tried the M7RR but i run many sets of M3:s,M5:s and Racetechs and can't find anything bad to say about them. I allso ridden Pirellis Diablo Corsas and i like the Metzelers feedback more but the Pirellis have allso very much grip. No problem scraping the pegs on my 954 when they are at lowest position (still higher then stock). What Pirelli Diablos have you used? I have at the moment Super Corsa SC-2 track tire at the front and Rosso2 rear wheel and they seem to grip fine. I had SuperCorsa SP on the front a while ago and it was the best front for street use i ever had. The track tires allso have a great grip when they warm up but they are much slippery when cold and if the weather is cold i'll have to rsun them pretty hard to get them warm.
I actually had similar looking puncture on my Corsa 3 rear years ago but bigger. And i never found anything inside the tyre or from the ground. And it did go flat in seconds so i stopped right away and tried to look from the road butnothing. I did fix it with and drift/burn the tyre few km:s with it before it was finished and changed it to a new one.
Just one last note, since the split is in the centre of the tyre I am surprised that if I did hit something, the front should have hit it too but it is completely unmarked. Also in my defense I didn't say it wasn't just bad luck, it could well be , but this is a new type of tyre and has only been out here for 5 months and if there is an issue with it I just want people to be aware of my problem. And Hawkwind, it wasn't out of my sight the whole time so I can rule out any interferance with the tyre.
